Creaking steering noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2006, 09:53 PM   #1 (permalink)
View camboy's Photo Gallery
Canada Creaking steering noise
My 1999 Camry V6 XLE with 45000 miles makes creaking noise from the driver's side front end when I do mostly right turn. I took the wheel off and had a look but did not see anything broken like the drive boot. Any idea what could be causing this noise? Are ther anything there that needs to be oiled?
Thanks
Camboy
camboy is offline   Reply With Quote
Old 03-10-2006, 10:05 PM   #2 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
make sure to check the strut mounts, CV Joints/Boots. THose are the common causes of that creaking sound. Hopefully your CV joint isnt busted because one of those cost over 100 dollars.
nodrogkam is offline   Reply With Quote
Steering Wheel Noise Trd_Thunder 2nd Generation (2005+) 9 02-21-2007 12:05 PM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 12:34 PM
Steering Noise taimurakhter Camry & Solara Lounge 8 04-04-2005 08:18 PM
Moaning/squeeling kinda noise when turning (noise in steering column) SolaraTRD General Discussion 4 12-30-2004 01:41 PM
Power steering noise hdsalinas Archived Corolla threads 2 08-22-2004 10:25 PM
