KYB GR2's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2006, 01:50 AM   #1 (permalink)
Camry Under Construction
05Cam-Weasel's Avatar
View 05Cam-Weasel's Photo Gallery
Gen5 KYB GR2's
ok i just ordered eibach springs that give my car a 1.5" drop and i was wondering if the KYB GR 2's for a 2002 camry would work for a 2005 camry?? They didn't have any for the 2005. Also if they would work, are the KYB GR2's shocks and struts or just shocks?
Thanks for any response!
Wesley
Weasel(n.)- A naive user, one who deliberately or accidentally does things that are stupid or ill-advised.
05Cam-Weasel is offline   Reply With Quote
Old 03-12-2006, 04:44 PM   #2 (permalink)
View freestylez's Photo Gallery
yes they would fit the 2005's
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 03-12-2006, 07:40 PM   #3 (permalink)
.::{ XwORLD }::.
View Obelix's Photo Gallery
just go to KYB.com and then find the list that has all the camry years and part numbers... just look if the part numbers are the same...
Gen4|Mobil 1|Michelin|K&N|93 Octane|V6|Silverstar|KYB GR-2|
Obelix is offline   Reply With Quote
Old 03-12-2006, 09:48 PM   #4 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
i believe the GR2's are shocks.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 03-12-2006, 09:51 PM   #5 (permalink)
not your average bear
View justchillinjefe's Photo Gallery
struts
justchillinjefe is offline   Reply With Quote
Old 03-13-2006, 12:31 AM   #6 (permalink)
So the question is: on ebay there are a set of 4 GR2's for sale. If I bought those, could I put all four on and I would be set? Also, I have 4 Eibach springs being shipped in right now.
Wesley
Old 03-13-2006, 03:10 AM   #7 (permalink)
how many miles u got on ur car? i recently got new front&rear KYB struts at like 65000 miles for about $250 for all four
2000 CAMRY CE
Old 03-13-2006, 02:20 PM   #8 (permalink)
15,000
Old 03-13-2006, 04:11 PM   #9 (permalink)
Originally Posted by 05Cam-Weasel
15,000
i think it is too early to replace your struts at only 15,000 i read your other treads of the problem you were havent and i doubt replacing your struts will solve that issue
2000 CAMRY CE
Old 03-29-2006, 03:32 AM   #10 (permalink)
View CamryEvolution's Photo Gallery
Hey Guys,
I drive a Gen 5 Camry LE, 4-cyl. I have purchased set of 17" rims on 225/45/17 tires. I have a heavy system in the trunk, which pushes the rear lower than normal, and that's why I plan on purchasing H&R Sport lowering spring, since several TN members told me that H&R Sport drops noticeably more in front than rear, and in my case, I hope it will even the car's height.
The problem is, when I called Tire Rack couple of days ago and asked them about the KYB GR-2 struts, having told them all the information that I stated above, the guy told me that GR-2's are not meant to used with lowering springs, and that I should look into KYB AGX instead. I did some search on KYB AGX for my car's application, but did not find any.
Can someone let me know if the guy from Tire Rack was correct about his statement? If so, what would you recommend as for struts replacement?
Thanks a lot.
CamryEvolution is offline   Reply With Quote
Old 03-29-2006, 04:34 AM   #11 (permalink)
ToyCam05
View PinoyBoy28's Photo Gallery
Gen5
i believe that the guy from tire rack is correct. when i was tryin to find new shocks for my 92 accord because shocks were leaking caused of my coil springs i dropped my car about 2". this guy from honda fiend said that gr2s are more for stock springs and agx are more for lowerd springs.. so i got the agx's... I also think that you would be better off with the kyb agx, tokico, or other adjustable struts out there.. it will be more stiffer that way and better handling too...
PinoyBoy28 is offline   Reply With Quote
Old 03-29-2006, 05:44 AM   #12 (permalink)
The Other White Meat
terrastrife's Avatar
GR-2s are only rated for 1" drop, they wont give warranty for applications lower then 1" from standard.
so just dont tell them.
terrastrife is offline   Reply With Quote
Old 03-30-2006, 12:54 AM   #13 (permalink)
Thanks for the input guys. But my next question is: neither KYB's AGX nor Tokico's adjustable struts have applications for Gen 5 Camry, do I have any other options that the cost around $400-$500? If not, then am I better off using the stock struts rather than the KYB Gr-2's?
Thanks a lot guys.
Old 03-30-2006, 01:20 AM   #14 (permalink)
i have kyb gr2 struts with h and r springs with about 1.3 in. drop in front and 1.2 in back
handles great
Old 03-30-2006, 01:40 AM   #15 (permalink)
How long have you had the H&R Sport lowering springs on? Because I thought that H&R Sport supposed to drop noticeably more in the front than the rear, like I was told by couple of other TN members.
If the actual drop for your car (after the springs settled) is, like you stated, 1.3 in front and 1.2 in rear, what springs would you recommend for my application? Knowing that I have Gen 5 4-cyl with a heavy system in the trunk, which pushes the rear lower than normal, and I would like a set of lowering springs (not too low of a drop) even out the fender gap in front and rear, you know what I mean?
Thanks a lot.
KYB ( any non OEM ) Strut mount for Gen3 Camry? Front? blueapple 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-26-2008 11:36 PM
KYB GR2 drop questioned – Answered by KYB dirtdiggler Camry & Solara Lounge 4 11-09-2005 09:17 AM
KYB Gr2's just2asian Camry & Solara Lounge 18 10-13-2005 06:45 PM
Kyb Gr-2, Gas-a-just..?? Difference..?? ptycamry Camry & Solara Lounge 3 10-13-2005 12:18 AM
HELP KYB GS-2 struts SUCK ! dctodd Camry & Solara Lounge 8 04-08-2003 08:26 PM
