USed car with no history, why take chances?
Buy this
http://www.auto-rx.com/
Follow the directions for sludge
FIRST APPLICATION
STEP 1
Change the oil filter*
Install a new oil filter to give Auto-Rx® a place to deposit sludge, dirt, contaminants, and third-party abrasives cleaned from the engine.
STEP 2
Add Auto-Rx® to the oil
Pour 12 full ounces of Auto-Rx® into your existing oil.
If your engine oil capacity is not 6 quarts then for correct amount to add.
STEP 3
Cleaning Phase
Drive 1,500 miles.
STEP 4
Rinsing Phase
Change the oil and oil filter (use non-synthetic oil for this step).
STEP 5
Drive your car an additional
2,000 miles with just the new oil and filter.
SECOND APPLICATION
STEP 1
Change the oil and oil filter*
Continue to use non-synthetic oil
STEP 2
Add the second bottle of Auto-Rx®
STEP 3
Cleaning Phase
Drive 1,000 miles.
STEP 4
Rinsing Phase
STEP 5
Completion Phase
Oil and filter should next be changed between 2,000 and 3,000 miles.
Auto-Rx Ongoing Maintenance Plan
For continuous and long-term protection 3 ounces of Auto-Rx® should be added with each oil change. In addition, you should continue to use non-synthetic oil for maximum benefit.
