Mode button Temp/Clock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2006, 01:27 PM   #1 (permalink)
View trickyazn's Photo Gallery
4th Generation Mode button Temp/Clock
Everyone knows theres a mode button on the clock.. press it will change from time to temperature.. anyone knows how to make it default? I personally prefer it over the clock.
trickyazn is offline   Reply With Quote
Old 03-12-2006, 03:38 PM   #2 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
i don't have that on my 99 gen 4, what gives?
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 03-12-2006, 04:08 PM   #3 (permalink)
Gameroom cash: $304355
I believe it started on the generation 4.5's. (2000 & 2001)
Mike
Old 03-13-2006, 11:02 PM   #4 (permalink)
anyone still have a clue?
Old 03-15-2006, 09:35 AM   #5 (permalink)
cdncamry's Avatar
View cdncamry's Photo Gallery
You can't change it. default is always clock, bummer i know.
2001 Civic Lx, I/H/E - 15.72 @ 88.5MPH
2000 Camry CE 2.2 Auto - 19.6 MPG
cdncamry is offline   Reply With Quote
Old 03-28-2006, 12:11 AM   #6 (permalink)
View AmanO's Photo Gallery
Resurrected!
Are the harnesses the same for the clocks in gen 4-4.5?
I am assuming not, but hoping so.
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
Old 03-28-2006, 02:08 AM   #7 (permalink)
1999 Gen4 V6
AustSV21's Avatar
View AustSV21's Photo Gallery
does anyone have a picture of one? i don't have any clock in my camry, except on my head unit.
would i be able to transplant one into my gen 4?
AustSV21 is offline   Reply With Quote
Old 03-28-2006, 02:22 AM   #8 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
i used the drive a Gen3 Camry, and my model didnt come with a Clock either...i took apart the dash and there was wiring for it (its a bit hard to see, you might need to hunt for it).
so i went down to the junkyard/wreckers and bought one used, and it was plug and play
as for the Gen4 Camrys, im pretty sure the wiring will be there aswell (but i recommend checking before you do anything), if there is wiring, just get one from another Gen4, and then you will be good to go
thats for the Australian Built Camrys though, i wouldnt have any idea about the US Built Camrys
~ Terry
terrynham is offline   Reply With Quote
Old 03-28-2006, 03:21 AM   #9 (permalink)
Aust......what does your dash look like then? Is the bezel around the cluster different?
Old 03-28-2006, 03:36 AM   #10 (permalink)
The Other White Meat
terrastrife's Avatar
dude... we sit on the other side of the car...
think for a minute =)
terrastrife is offline   Reply With Quote
Old 03-28-2006, 07:25 AM   #11 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
http://www.golfballmall.com/camry/pg10.htm
pic was taken before i bought the car.
look next to the speedometer, above the main a.c vents
skewe is offline   Reply With Quote
Old 03-28-2006, 12:05 PM   #12 (permalink)
4th Generation
Does it matter which side you sit on? Unless you sit in the back when you drive, the dash will prolly be the same except reversed. Same steering wheel, same stereo, sav HVAC...just in different places.
I was, though, unaware that Aussies were right hand side drivers.
The reason I asked is I dont want that green clock anymore and wondered if they made a bezel that covered it up.
Old 03-28-2006, 05:09 PM   #13 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
yeah for the models without a digital clock here, yes they did make a little bezel to cover it up...(looks the same as the opposite side i think).
but since the dash is reversed for us, i dont think it would fit where your clock is located...
~ Terry
Old 03-28-2006, 08:54 PM   #14 (permalink)
1999 Gen4 V6
AustSV21's Avatar
thanks guys
i had a look for wiring but couldnt find any
i guess its no clock for me
Old 03-29-2006, 07:21 AM   #15 (permalink)
skewe's Avatar
thanks guys
i am sure ur able to get something from the junk yard
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
Door Ajar Button SR5_4WD Archived Corolla threads 2 01-02-2006 06:35 PM
Factory Alarm Programing Mousiee Camry & Solara Lounge 15 06-29-2005 07:13 AM
