Degree of dificulty flex pipe+cat replace? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2006, 02:10 PM   #1 (permalink)
View hellomota's Photo Gallery
There is something wrong with my flex+cat assembely as it is making this loud flapping noise as I accelerate coming either from cat or flex pipe. On the internet I found the whole assembely starting at headers and all the way to cat for 200 shipped. I was just wandering how hard would it be to replace it myslef (I assume its just bolt on) what insturments would I need and is there some kind of seales on the ends of assembely. I have 97 4cl camry by the way.
Thanks alot for the help in advance, I really apreciate it.
hellomota is offline   Reply With Quote
Old 03-12-2006, 02:38 PM   #2 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
not hard at all, you will need a couple of gaskets. Will be a little more difficult on the ground but not bad
BadChicken is offline   Reply With Quote
Old 03-12-2006, 02:39 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
You need som ePB blaster to spray on the nuts and bolts before you start. the actual ehaust nuts are 14mm. It will help to have a deep well socket so you can get it over the exhaust studs. There are 2-3 at the manifold and then 2 at the cataliytic converter. THere is a hanger that you can slide a hook attached to the pipe out of right about where the firewall turns into the lower floor pan. You can remove the entire hanger with a 12mm socket and then take the hanger off if youthink it would be easier. YOu will need extensions ong engouh to get to the manifold bolts from under the car also. ALl in all you can probablyhave it done in an hour or so. Not hard at all. If you dont have any way to jack the car up and put it on jackstands then it will take a little longer probably. On a scale of 1-5 1 being the easiets I wold give it maybe a 2 or 3.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Flex Pipe and Emissions Cello8619 Camry & Solara Lounge 6 06-13-2005 08:43 PM
Gen 4 V6 Y pipe & hi flow Cat recommendations 1kdude 3rd & 4th Generation (1992–1996 & 1997–2001) 1 04-17-2005 06:27 PM
Hollowed out front cat. you think it will cause an CEL EMMETT03 Camry & Solara Lounge 10 01-09-2005 09:45 AM
Making a straight pipe for the secound cat in 3Gen booster1 Camry & Solara Lounge 1 09-03-2002 08:04 PM
