Air filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2006, 10:39 PM   #1 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Air filter
Ok, this is a stupid question, but I'm going to ask it any way because I dont want to damage anything. Is changing the air filter just a matter of removing the two bolts and then I lift the cover and the hoses attached to the cover are flexible enough for me to move it out of the way to remove the old filter and insert new one. Is that it? Anything to watch out for?
By the wawy, its a 2002 V6 Camry
Thanks
ToyotaToday is offline   Reply With Quote
Old 03-12-2006, 10:49 PM   #2 (permalink)
View freestylez's Photo Gallery
yes its that easy but just make sure all the tabs and clips are aligned and clipped back properly
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 03-12-2006, 11:13 PM   #3 (permalink)
View STANJ's Photo Gallery
indeed. just the clips. Just watch out for the alignment of your air filter and the air filter box. If the air filter is not alignment properly, you might have difficulties putting the clips together.
STANJ is offline   Reply With Quote
Old 03-13-2006, 12:32 AM   #4 (permalink)
2002 Camry
Forgot to mention, it's a 2002 V6.
Old 03-14-2006, 12:02 AM   #5 (permalink)
2002 Camry
Gen5
What you told me? Does this apply to V6 2002 Camry. So just two bolts to remove the air filter cover and that's it.
2006 4Runner Limited
Old 03-14-2006, 07:00 AM   #6 (permalink)
yes
2000 CAMRY CE
Old 03-15-2006, 12:10 AM   #7 (permalink)
2002 Camry
Gen5
ok, i changed the filter, and put everything back in nicely. everything all aligned. BUt I still see the outer edges of my filter. Is this normal?
Old 03-15-2006, 12:15 AM   #8 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
^ edges ? it could be apart of the airbox which looks like edge. If it sounds funny when you rev high then your airbox is not aligned either than that dont worry about it.
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 05-15-2006, 06:20 PM   #9 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Lightbulb
It's not a bad idea to lightly grease the lips of the new air filter before you install it.
I do this when as soon as I get a new vehicle in my garage (car or motorcycle).
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Breather hose to air filter aldwinenriquez Archived Corolla threads 0 08-25-2005 05:49 PM
changing air filter on gen3 5SFE jaguar 3rd & 4th Generation (1992–1996 & 1997–2001) 6 08-17-2004 06:59 PM
Install Air Filter MR2 Turbo javier80 Hardcore Tech and Competition 5 07-25-2004 06:58 PM
Short Ram Air Filter The Wolf Camry & Solara Lounge 2 07-25-2004 03:18 AM
best oil, oil filter, and air filter? njbmx Camry & Solara Lounge 3 10-19-2003 07:39 PM
