Check Engine Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2006, 11:07 PM   #1 (permalink)
View Flash43545's Photo Gallery
3rd Generation Check Engine Light
Hi I am new to the forums My name is RObert i also have a check engine light on the 1996 camry it seems that in idle the rpm's drops a tad below 800 rpms the car will shake slightly and quickly rise to 900 rpm then the shaking will stop but also under the check engine light there is another light on with the shape of the car looks like it is indicating tail lights but all my lights are working fine. I know know what could poosibly be wrong. the car runs very smoothly just cant figure it out.
Any ideas would be appreicated
Flash43545 is offline   Reply With Quote
Old 03-12-2006, 11:14 PM   #2 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
for the car light dont forget about the middle back light inside the car....not just the tail lights. as for the idle problems first take it to an autozone or sumthing and have them hook it up to an OBD-2 reader, thats the best place to start. its most likely an IAC problem of some kind but then again who knows.
ag6286 is offline   Reply With Quote
Old 03-18-2006, 08:44 PM   #3 (permalink)
View marc780's Photo Gallery
Flash, before you pull codes (the next step) check all the vacuum hoses on the engine carefully. Sounds like you could just have a simple vacuum leak. Examine the hoses carefully and make sure they are all plugged in and not popped loose from their fitting. Look for cracked and broken hoses too, usually at bends is where they crack. Replace any bad hoses with new.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 10:00 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
Check Engine Light clp86rom Archived Corolla threads 13 06-17-2006 09:02 PM
