Steering pump making noise... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2006, 06:24 PM   #1 (permalink)
View mike6789's Photo Gallery
4th Generation Steering pump making noise...
Whenever I turn the wheel more than about 40 degrees either way, the pump makes a buzzing noise... Does this mean its a bad pump or just the fluid is low? How do I check the fluid and where is the pump located?
It's a 97 camry LE gen 4 i think
Thanks
mike6789 is offline   Reply With Quote
Old 03-14-2006, 07:43 AM   #2 (permalink)
View hooRAH's Photo Gallery
Probably that the fluid is low. Resivoir is on the left, next to the coolant. Its in your owners manual.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 03-14-2006, 08:28 AM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Check the fluid first. More than likely it is the cause. The PS pumps on Toyotas seem to leak after a decent amount of mileage. I jsut had to replace the pump and rack on my 94 with 85k miles on it. I have also noticed some seepage from the pump on my Sienna withthe same V6 engine in it.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Clicking noise from steering wheel Tango 1st Generation (2003-2008) 5 01-10-2006 08:18 PM
Celica 2001 SQUEAL noise (Drive belt? Water pump?) PLEASE HELP - Ahhhh! mgcelica Celica Forum 6 02-18-2005 04:06 PM
Power Steering Pump Rebuild 92 P/u 3vze RICHIE Introduce Yourself Here 5 01-28-2005 04:06 PM
Steering noise after belt change. slcpunk Camry & Solara Lounge 3 07-20-2004 10:32 PM
