Oil Change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2006, 08:56 PM   #1 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Gen5 Oil Change
Hi
Do I need special tool SST 09228-07501 just to change the oil. I read the online repair manual and it states using this tool to tighten/loosen the filter. Is this necessary?
Also, where is the drain hole for the oil. Is the drain hole the filter itself? The instructions aren't too clear.
Thanks
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 03-13-2006, 09:37 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
NO you do not have to have the SST to change the oil. It is a tool taht goes over the end of the oil filter to act as a socket sorta. You should be abele to loosen it by hand.
as for the drain plug it is on the bottom of the oil pan. Crawl under the car and you will see a 14mm bolt on the backside/botttom of the pan. Remove it and watch out because the oil drains fast.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 03-13-2006, 10:11 PM   #3 (permalink)
2002 Camry
Gen5
Thanks Man. I'll check it out.
First Oil Change Free? BobL94901 2nd Generation (2005+) 15 12-09-2006 09:12 PM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
2003 Camry LE V6 3.0 Oil Change SuperGT 5th & 6th Generation (2002-2006 & 2007-2011) 15 03-14-2006 08:07 AM
2007 Camry pictures Meet Joe Asian Toyota News 919 01-09-2006 01:42 PM
2001 Sienna went to get an oil change. Oil Plug loose, leak all the oil ...what now? 2k1Sienna 1st Generation (1998-2003) 3 11-29-2005 09:16 AM
