Oil in my intake!??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2006, 02:32 PM   #1 (permalink)
View The Black Camry's Photo Gallery
For some odd reason I have oil in my intake but the weird thing is i have no turbo. so what could it be?
The Black Camry is offline   Reply With Quote
Old 03-14-2006, 02:41 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
It could be residue coming in from a faulty PCV valve. Are you sure it's oil? Maybe it could be carbon build-up...sometimes it forms as a tar-like black substance. A little throttle body cleaner will clean it all out (search this forum and you'll find several threads).
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 03-14-2006, 03:29 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Yeah probably normal PCV operation. Is it more of a film or is oil actually puddling in the intake. You can have it come from the PCV valve itself or sometimes there is a vent hose on the front of the alve cover that leads directly into the intake tube, instead of eh throttle body and you will get some oil residue from taht also.
Like he said get some throttle body cleaner and spray it out and you should be good to go.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 03-14-2006, 04:49 PM   #4 (permalink)
no this is actual oil! Its like if i had a blown turbo. The oil Is actually puddling up!!!!
Old 03-14-2006, 07:08 PM   #5 (permalink)
View Gary_602Z's Photo Gallery
A broken ring or cracked piston will do the same thing. Take the oil fill cap off while the engine is running. Do you see excessive blowby? Stick your hand over the oil fill for a few seconds and then release it to see if you are building excessive crankcase pressure.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 03-14-2006, 08:34 PM   #6 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
Maybe it could be some oil getting through throddle body or somewhere around there.
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 03-14-2006, 08:44 PM   #7 (permalink)
well i diconected the hose that goes from the valve cover to the throtlle body and pressure did build up and some white smoke came out the hose. and the engine wasnt realy warm!... But how could a blown ring make oil puddle up in my throttle?
Old 03-15-2006, 03:00 AM   #8 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
when was the last time u changed ur pcv vlave. cause if the pcv vlave its clogged pressure will build up in ur engine and force oil up into ur throttle or out your valve cover cause it has no where else to go.
project92camry is offline   Reply With Quote
Old 03-15-2006, 10:22 AM   #9 (permalink)
which one is the pcv valve?
Old 03-15-2006, 03:40 PM   #10 (permalink)
Pabloso
the theres 2 hoses comming out of the valve cover. the one thats closer to intake manifold. pull it off from the valve cover and that should be ur pcv. if u shake it , it should make a raddling sound .if it dont, then its not working.
Old 03-15-2006, 04:01 PM   #11 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Lightbulb Think about this....
This has to do with film build up in the plenum and injectors...
Consider this: each time you turn the engine off there are fuel and oil vapors stuck in the intake plenum with no where to go. As the engine cools, they go from a vapor to a solid and stick to everything. Hence the varnish like buildup common to the intake plenum.
Like they said earlier, if both valve covers are not vented - (PCV system not working), your engine may build internal pressure. Once this gets underway, seals and gaskets start to pass fluids, then she gets messy.....
I second that Oil standoff from the filler cap removed (engine running) is a sign of lots of blow by. Do a compression test. Chances are, you have a broken ring or the engines was not cared for in its prior days.
Oh - broken rings allow hot gasses passed the rings into the crankcase on the compression stroke. The PCV system can only handle a small amount of blowby. When it becomes excessive, the vapors turn to solids and you have oil in the PCV hoeses which connect to the intake. Make sense? Hint, a healthy engine will have a vacumm at idle in the crankcase, not pressure.
/ra
73sport is offline   Reply With Quote
Old 06-16-2006, 05:46 PM   #12 (permalink)
View southern star's Photo Gallery
Hi i have the 98 4cyl and it was using alot of oil so after a lot of tracking back this is what i found, It may help you please ref my post below.
It mabe happening to you as well.
Happy hunting.
http://www.toyotanation.com/forum/t140600.html
southern star is offline   Reply With Quote
motor oil mishap minime3 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-14-2006 09:32 PM
Can I use Synthetic motor Oil at 5k miles? Meteor_Proof 2nd Generation (2005+) 39 04-07-2006 01:00 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
1990 N/A Auto :( dave_id Supra Forum 6 08-26-2004 12:18 PM
Better Oil filter for Camry TRDragoon Camry & Solara Lounge 44 12-08-2003 02:38 PM
