Where is strut mount? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2006, 12:26 AM   #1 (permalink)
View CX889's Photo Gallery
4th Generation Where is strut mount?
I've read through threads about strut mount but didn't really realize where is it locate in. I took a few photos under my car and I am curious to know where. I saw one of the threads saying that spraying silicone helps to eliminate the noise a bit. Thought I'd try it out and see how's the result. If not too much trouble, just copy and make a mark at the photos so I know where is the strut mount. Thanks!
2010 Venza V6 AWD / Magnetic Grey Metallic / Navi and JBL Package
CX889 is offline   Reply With Quote
Old 03-15-2006, 12:28 AM   #2 (permalink)
View mspringer's Photo Gallery
Its not in any of those photos.
Its on TOP of each strut assembly, basically. Sandwiched between the car body and the top of the strut.
mspringer is offline   Reply With Quote
Old 03-15-2006, 12:56 AM   #3 (permalink)
View leasaunce's Photo Gallery
its near the top. its where the Strut n spring sits.
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 03-15-2006, 01:30 AM   #4 (permalink)
Would it be the 2 black circle thing inside the hood?
Old 03-15-2006, 06:47 AM   #5 (permalink)
View hclee25's Photo Gallery
^^^ yes!
hclee25 is offline   Reply With Quote
Old 03-16-2006, 08:24 PM   #6 (permalink)
So where would we spray the silicone lube? Is it inside the black thing?
Old 03-16-2006, 10:07 PM   #7 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
I'm curious on what kind of silicone your spraying in there. I have the same problem, and want to see if there's another other way to solve it without switching out parts.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 03-16-2006, 11:38 PM   #8 (permalink)
View STANJ's Photo Gallery
silicone lube sprayed at the strut mount area might not solve any problems at all. At least not to my knowledge. You might want to try to tighten your struts bolt which is sitting in the mount first. That may help, if you're one of the lucky ones that haven't blown your struts yet.
STANJ is offline   Reply With Quote
Old 03-17-2006, 12:27 PM   #9 (permalink)
My car is around 76k and whenever I go for bumps and uneven surfaces the noise always there. I know that spraying silicone lube would not be a long term solution. But if I really want to spray and see what's going to happen. Where should I apply the lube? Do I need to unscrew all the bolts and do it?
But I will try tighten all the screws first and see if its becomes a little bit better.
Old 03-17-2006, 12:29 PM   #10 (permalink)
Call Me Evolution Racer
TRDCamryCL's Avatar
View TRDCamryCL's Photo Gallery
Have you replaced your struts before?
- 5QU1NTYC4MZ - #1 BOOST WAY OR HIGHWAY Camry project is over and no more.
2004 VW GLi 1.8T w/ GT30R.
TRDCamryCL is offline   Reply With Quote
Old 03-18-2006, 11:51 AM   #11 (permalink)
No it's the stock one.
KYB ( any non OEM ) Strut mount for Gen3 Camry? Front? blueapple 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-26-2008 11:36 PM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
How many parts are there to a 94 Camry strut mount? green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 1 02-16-2006 07:48 PM
97-01 strut mounts Trdkamuri510 3rd & 4th Generation (1992–1996 & 1997–2001) 8 02-05-2006 08:54 PM
Tokico with KYB strut mount and boot? _VVTi_ Camry & Solara Lounge 1 03-15-2005 09:47 AM
