Question about strut mounts.. Search to no avail! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2006, 10:30 AM   #1 (permalink)
View newbie212's Photo Gallery
My wife's 97 camry v6's front suspension is making a crunching noise.. I tightened the 19mm bolt on top of the strut and it made the noise a little better.. Now it is back.. I plan on replacing the strut mounts but when I called Advanced today they said are you sure you dont need the "bearing plate". They have a listing for bearing plates and strut mounts.. Which one do I need or do i need both? Thanks
newbie212 is offline   Reply With Quote
Old 03-15-2006, 10:54 AM   #2 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Look for sturt mounts on the search section here (specific to camry's).
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 03-15-2006, 11:51 AM   #3 (permalink)
View steve97's Photo Gallery
There is a lot of info about strut mounts and bearing replacement. Mine is a 97 also, and I had to replace mounts , bearings and struts 50K ago.
Gets rid of all of that crunching and jarring sound up front.
steve97 is offline   Reply With Quote
Old 03-15-2006, 07:19 PM   #4 (permalink)
97 Camry
View Davee's Photo Gallery
Where exactly do these things fail -- Is it in the end just a noise you are paying to get rid of? My 97 has never had this di=one at 193,000Km
Davee is offline   Reply With Quote
Old 03-15-2006, 08:09 PM   #5 (permalink)
View 02Wiley's Photo Gallery
The mounts fail often and some have 50K miles on them when the do fail. Most of the time it is the mount itself that fails. I've done a some where i replaced the mount and still had the noise and i had to end up replacing the strut also.
02Wiley is offline   Reply With Quote
Old 03-15-2006, 09:16 PM   #6 (permalink)
Official TN member
View tracyf's Photo Gallery
If the struts on a front wheel drive car like this are allowed to go long enough without replacing them when they need to be replaced, they will eventually allow the steering knuckle to travel so far downward that it will damage the CV joint boot, all the grease will eventually be lost, and the CV axle will fail. Subsequent axle replacements are the proverbial "peeing in the wind" until the strut situation is resolved - I know this from all-too-personal experience. God Bless.
www.tracystruesoaps.com
tracyf is offline   Reply With Quote
Old 03-16-2006, 11:24 AM   #7 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
^^ on early year gen4's they failed early and they continued to fail.
Toyota replaced the part number and the part was re-engineered. The new part number now solves this problem. I'm on my 4th set of strut mounts at 80K miles and since then its been quiet ever since! Before this, the problem came back every 10K miles or so...
Old 03-17-2006, 12:47 PM   #8 (permalink)
97 Camry
4th Generation Only a V6 problem 97 strut mounts?
Where to buy strut mounts (researched) DAMON Camry & Solara Lounge 8 02-20-2005 08:30 PM
Strut Mounts crah Camry & Solara Lounge 4 11-25-2004 11:39 PM
TRD strut question FlaK Celica Forum 1 03-04-2003 12:47 PM
Strut Bar Question Phanatik Camry & Solara Lounge 1 12-06-2002 07:53 AM
