I kno I kno the worst thing to do really is re-use key gaskets but the fact is i don't have the money for them.
I need to reconect my knock sensors on a v-6 3vz-fe. So for those who don't know where those are they require me to remove the intake plenum and the intake manifold, which means i would normally need new gaskets for these however i was wonder if there was compression in these areas that i would really need new ones.
there are less than 4200 miles on the gaskets. The way i figure it if there was no real compression i could use some silicone spray of some kind and spray it on the gaskets and place them back as close i could to the orig position and everything would for the most part be okay.
Should it really be a big priority to change them since they are so relatively new and if i'm going to try and use some sealers?
again i know you should always change them but $$$ talks...its about $80 for the two gaskets at advanced autoparts
**also for when i go to do this do i have to disconnect the feul rails and injectors (from eachother) in order to take off teh intake manifold or do i just have to disconnect teh lines from the rails and pull them off?
**about the fuel pump, the engine should be pushin about 250+HP after everything is fixed properly, i was curious if the feul pump could keep up with this or if it would burn out within a few days? the fuel pumo has 215000 miles on it
