Mr2 Gearbox mods - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 05:21 AM   #1 (permalink)
Ferrat
Ferrat's Avatar
View Ferrat's Photo Gallery
2nd Generation Mr2 Gearbox mods
Hey,
I was wondering what i would have to do to mod a gearbox from a Mr2 into a gen 2 camry.
I'm planning a 3s-gte and would like the LSD and gear ratios from the MR2 gearbox then the e153. So any info would be greatly appreaciated.
Thanks
1989 Camry SV22 (RIP) Blown Motor
1988 Camry SV21
2001 Camry MCV20 V6 Touring
Ferrat is offline   Reply With Quote
Old 03-16-2006, 02:39 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
Originally Posted by Ferrat
Hey,
Thanks
Easiest way (since you are down an Aus)...
Get and MR2 gearbox and an ST185 gearbox and make a hybrid. All the parts you need will be found between the two gearboxes. One of them can be totally busted because you have parts form the other box to make up for it.
The side mount should be from the ST185 (top side)
Front mount should be part ST185 part SV21 manual
Rear mount should be part ST185 and part SV21 rear with new holes in the crossmember
V6 axles work, but you will need the stub/carrier behind the motor for the MR2 turbo and V6 hubs.
That should get you on your way...
-Charlie
PS. This is approximately what I'm doing on my Camry right now... (ST205 box modified with MR2 parts, KAAZ LSD, MR2 inner axles, V6 outer axles with V6 hubs)
white90dx is online now   Reply With Quote
Old 03-16-2006, 03:38 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
As White said, make a hybrid. Grab an MR2 gearbox, and swap some parts to make thhe linkage correct. The 2VZFE AUTO axles will work with the E153 gearbox. (go to that wreckers i told you about, theyll have it if your quick )
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Turbo MK2 MR2 vs turbo 20v MK1 MR2? aaron7 General Discussion 6 02-22-2006 11:38 AM
Tercel and MR2 80tercelproject Tercel, Paseo, Starlet, and Sera Forum 8 02-12-2006 01:26 PM
For Sale: 1991 Toyota MR2 non-turbo automatic (many pics) LarryDallas Vehicles 2 07-07-2005 03:15 AM
2006+ Mr2 Piddy Toyota News 18 01-12-2005 09:46 AM
91 MR2 Mods? Unholy MR2 Forum 7 10-31-2003 11:03 AM
