Power problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 08:35 AM   #1 (permalink)
Rally_9RPM
redline_mr2's Avatar
View redline_mr2's Photo Gallery
2nd Generation Power problem
My friend has a 1989 Toyota Camry LE. He just hit 100000 miles a few days ago. He was doing replaced the cig lighter and installed a dual one. But now the dome light isn't working and the little lights in the shifter won't work as well as the light in the cig tray. Does anyone have a clue what to check? Or any tools I am going to need?
redline_mr2 is offline   Reply With Quote
Old 03-16-2006, 01:35 PM   #2 (permalink)
View Bluecam6's Photo Gallery
IF all those lights went out at the same time it should be just a fuse. They are located
at the left (drivers side) lower kick panel. There are some fuses also under hood on the
top left wheelwell. But the fuse your looking for should be under the kick panel left side under the dash. If it is not a fuse maybe a ground but I don't think all of that stuff is
on the same ground. a good starting point is the fuses. It is also a good idea to use
a ohm meter to check the fuse.
Bluecam6 is offline   Reply With Quote
Help with Power Steering problem Troyfrezze Camry & Solara Lounge 3 06-09-2004 05:36 PM
3vz engine problem... no power zoni Hardcore Tech and Competition 10 05-19-2004 09:57 AM
'98 Camry CE Power Window Problem ast99 3rd & 4th Generation (1992–1996 & 1997–2001) 4 05-06-2004 10:38 PM
Power window problem on '95 Camry Conundrum 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-20-2003 12:36 AM
