temp gauge doesnt move - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 10:22 AM   #1 (permalink)
Andre
View 88Cam's Photo Gallery
2nd Generation temp gauge doesnt move
the temp gauge in my 88 camry doesnt move at all. i've done everything from changing the sensor, to the thermostat and the radiator. but its still down way below the cold mark. am i missing something or does my gauge need to be replaced
88Cam is offline   Reply With Quote
Old 03-16-2006, 12:00 PM   #2 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
Check the connections on the backside of the instrument panel and try to clean the contact points
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Old 03-16-2006, 12:12 PM   #3 (permalink)
Andre
when i looked back there they looked clean. i blew some air around to remove whatever dust was in there, and still no movement.
'88, 3SFE, auto
Old 03-16-2006, 02:28 PM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
Which sensor did you replace?
If it was the one with two wires, you replaced the wrong one...
The gauge cluster runs off the sensor with one wire. You can also take an multimeter and check the wire going from that sensor to the cluster - the wire color remains the same the whole way. If that doesn't work, find a gauge cluster in the junkyard and replace the temp gauge section of your gauge cluster.
-Charlie
white90dx is online now   Reply With Quote
Old 03-16-2006, 04:25 PM   #5 (permalink)
Andre
ok, well i'm guessing i changed the wrong one and that would explain why it still doesnt work
where is the sensor with one wire located? and if i change that and the gauge still doesnt work...would it be possible to change the whole instrument cluster with one that has a tach, and wire up the tach to make it functional as well? (i hate not being able to see my engine speed and i want everything to look like it was supposed to be there...which explains why i havent just gone to get an aftermarket tach)
'88, 3SFE, auto
Old 03-17-2006, 06:16 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Water neck... Right side of cylinder head.... Labeled water temp sender in pic below
Yes.
Its plug and play, no wiring necessary.
Just make sure to get the right one for your car. I4 and V6 gauge clusters are different.
"Skoolin' the unlearned!"
Old 03-17-2006, 08:07 AM   #7 (permalink)
Andre
thanks 88LE, i guess i'm off to the junkyard now for a water temp sender and the cluster.
oh, one other question. will i have to hook up the tach or will it work as soon as the cluster is plugged in?
'88, 3SFE, auto
Old 03-17-2006, 08:08 AM   #8 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Will work as soon as its plugged in. The tacho wires are already in the loom.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-17-2006, 08:43 AM   #9 (permalink)
Andre
this wouldn't happen to be the plug for the water temp sender that's UNPLUGGED would it?
http://us.a1.yahoofs.com/users/41c13...ACtGEBJ.iWKqgM
:edit: nevermind, apparently the reason my temp gauge stopped working is be cause the little blue plug in the pic above somehow was unplugged. so now my temp gauge works, but i'm still going to get that cluster with the tach.
has anyone ever came across the instrument clusters for a 4cyl on ebay?
'88, 3SFE, auto
Old 03-19-2006, 12:03 AM   #10 (permalink)
white90dx's Avatar
When you get the cluster (best bet is a local junkyard...), swap over your current speedo assembly and you can even keep things correct for you car.
-Charlie
(and yes, it really is plug and play - everything just works as long as you get the cluster for the correct engine)
Old 03-19-2006, 07:09 AM   #11 (permalink)
Andre
hey thats a good idea. why didnt i think of that? i was just going to try to roll the miles to match mine on the new cluster.
'88, 3SFE, auto
Old 03-19-2006, 11:48 AM   #12 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
but what if it's higher milage than your own? which is usually the case @ junk yard cars
Old 03-19-2006, 11:55 AM   #13 (permalink)
Andre
well if thats the case, then i'm glad white90dx dropped that bit of information to make my life easier.
'88, 3SFE, auto
Old 03-19-2006, 04:55 PM   #14 (permalink)
Pochacco Owns Me
atobe's Avatar
hehehe it's easy to do the whole milage assembly's only held on by 2 screws so it's easy to swap em.. i swapped my cluster too it's really plug and play 5 mins to swap it
Old 03-20-2006, 01:50 PM   #15 (permalink)
Andre
thats the best news i've heard. cuz when i called the toyota dealer the guy was telling me that the wire number was different and he made it sound like i would have to completely rewire the new cluster. and then he went as far as to tell me to just get an aftermarket one, which there's no way in hell i was going to do that.
'88, 3SFE, auto
1993 Corolla/Prizm Temp gauge stays cold all the time dwikiz Archived Corolla threads 4 03-12-2006 12:49 PM
Temp gauge help andyb16 MR2 Forum 3 01-13-2006 12:58 AM
Temp gauge relay [gen2] Zfreeman 1st & 2nd Generation (1983–1986 & 1987-1991) 9 08-21-2004 07:00 PM
Help on hooking up oil pressure gauge & coolant temp gauge? Camdaddy Camry & Solara Lounge 4 01-20-2004 05:57 AM
