My 3rd Gen Camry will not start. HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 05:34 PM   #1 (permalink)
View Tarzan's Photo Gallery
Hey guys,
I have a 1994 Camry 4 cylinder automatic. 139k miles. Today it won't start at all. It just turns over and over again. I don't hear any clicking. The thing is yesterday it started and drove fine and now suddenly the engine won't start up.
I think the battery is ok because mine has the opening where you can see the color and also all the internal assecories come on. However, I did notice that the clock is wrong.
The timing belt was replaced at 56k and I think its over due. Also the spark plugs are 2 or 3 years old.
I'm been reading that the problem may be that the timing belt broke. Is there anyway that I can check if that is the real problem, I mean by DYI?
Anyone please offer comments and suggestions. Thanks in advance.
Tarzan is offline   Reply With Quote
Old 03-16-2006, 05:57 PM   #2 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
1. See if all the main fuses are in working order, especially the EFI fuse
2. Check if you are geting spark on your plugs, you probably know how to do that.
3. The distributor cap is also a thing you want to check, there may be water or condesation
in it so take it off the cap and have a look.
4. The timing belt cover is divided in 2 parts, you only need to take off the upper part
to inspect if the timing belt has snapped, a few bolts and it comes off easy.
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Old 03-17-2006, 01:24 PM   #3 (permalink)
Gameroom cash: $304355
To check on the timing belt all you need to do is remove the oil cap. Now have someone turn the key to try to start the engine while you look down inside the engine, where the oil cap normally goes. If you can see the cams moving (rotating), the timing belt is not broken. If you don't see any movement, then it is broken.
If you do the other things Zandro has suggested and don't get any spark, after you check the distributor cap and rotor, check the coil inside the distributor. You will need a DVM (digital volt/ohmeter) for this and the specs from any manual. Don't forget you can download the generation 3 manual at the top of this forum. I believe it actually is a 1994 Toyota Camry factory service manual.
With the mileage on the car since the last timing belt change, I would check that out first. It will take you 1 minute, if you have a second person to help you.
Mike
Old 03-17-2006, 06:44 PM   #4 (permalink)
Today I checked the spark by doing the following.
Unpluged the spark cable and inserted a phillips head screw driver into the boot and placed it on the engine block while I cranked it. There was no spark that I could see from all 4 cables.
Then I installed 4 new autolite platinum plugs, and the thing still don't start.
I also took off the oil cap while cranking and the camber is not turning, therefore is it the timing belt?
I smell gas everytime I try to crank it so I don't think it is the fuel pump.
Therefore I think it is the distributor, or timing belt.
Any other ideas? Thanks for your help thus far.
Old 03-17-2006, 07:07 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You sure the cams aren't turning?
Remove the distributor cap, theres just a few small bolts around the outside of the cap. Crank the motor and see if the rotor spins.
If the rotor doesn't spin, the timing belt is busted.
"Skoolin' the unlearned!"
Old 03-17-2006, 07:08 PM   #6 (permalink)
How much would it be to replace the belt? I'm hearing near $1000!!!!!!
Thanks
Old 03-17-2006, 07:10 PM   #7 (permalink)
rusty9's Avatar
Gameroom cash: $441505
View rusty9's Photo Gallery
no spark, no cam movement..sound like timing belt. wierd that it would just break after sitting overnight... anyway to double check, either do as said above and check the belt by removing the covers, or remove the distributor cap and see if the rotor is spinning as you crank it.
rusty9 is offline   Reply With Quote
Old 03-17-2006, 07:11 PM   #8 (permalink)
Grenaded piston
88 LE's Avatar
^^ $1000? No way.
Its around $200 at a Toyota dealership.
If you want to DIY, read this:
http://toyotanation.com/forum/t109966.html
^ Its for a 97 4 cyl., but its the same motor (5S-FE).
Old 03-17-2006, 10:10 PM   #9 (permalink)
N/A bites
Tercel GTS's Avatar
If you can't find a reasonable shop and don't want to try it yourself holler at me. Have tools, will travel! 5SFE does not bend valves before anybody asks.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-17-2006, 11:47 PM   #10 (permalink)
Like 88le said, it's around $200 when on special at most dealerships. If not on special, it shouldn't be more than $300. That would be plus the cost of a tow, so first make sure it is the timing belt. Do the second test that someone suggested of removing the distributor cap and cranking the engine. Some people have trouble seeing down in the oil cap area to see if the cams are moving. A moving or nonmoving rotor is sometimes easier to see.
You can try the link below to see if any dealerships in your area are listed and are having a special on timing belt replacement. In my area, most of the dealers with meet other dealers coupon specials in the same area:
http://www.toyotacoupons.com/UI/Deal...lerSearch.aspx
Mike
Old 03-18-2006, 12:21 AM   #11 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
timing belt are about 199$ at dealer
cheaper outside
skewe is offline   Reply With Quote
Old 03-18-2006, 06:02 PM   #12 (permalink)
Update:
Today I checked the fuses and they seem fine. I removed the distributor cap and saw that the rotor was turning, therefore its not the timing belt. I also replaced the distributor cap and rotor just to see if it would fix it. Still no start.
So what could be the issue? I'm guessing coil or starter? There is no way I can check that because I don't have the tools.
Thanks for all your suggestions guys. Please keep helping me.
Old 03-18-2006, 07:19 PM   #13 (permalink)
rusty9's Avatar
how did you check the fuses? with a circuit tester or by looking at them? also, did you check them all? evven the ones behind the coin box?
Old 03-18-2006, 07:23 PM   #14 (permalink)
I checked by just looking. There are some big fuses that look like cubes. They are not transparent, how do I check those? I did not check the fuses behind the coin box since those are only for interior dash lights, ect. I don't have a circuit tester.
But thanks for asking.
Old 03-19-2006, 12:41 AM   #15 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
U Can Get A Test Light Check Them While They Are Still In, Or Just Pull Out The Fuses That Can Be Affecting Your Problem And Check If They Are Burnt Out.
project92camry is offline   Reply With Quote
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
do any other springs fit on the 3rd gen camry 4cyl madmax3208 Camry & Solara Lounge 1 08-29-2005 10:16 PM
3rd Gen Camry DX Question mox Camry & Solara Lounge 8 06-18-2003 05:05 PM
can a 98 celica gt steering will fit on a 3rd gen camry?? Renaissance 3rd & 4th Generation (1992–1996 & 1997–2001) 5 12-31-2002 12:02 AM
