Replacing suspension, is this what I need? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 06:29 PM   #1 (permalink)
View caveman017's Photo Gallery
4th Generation Replacing suspension, is this what I need?
I'm replacing the front suspension in the 97' camry. Is this the parts I need and the best place to get them from? Also, dealer says I need rear stabilizer bushings.. any idea where I can get those?
http://www.tirerack.com/suspension/s...180&perfCode=P
http://www.tirerack.com/suspension/s...711&perfCode=P
caveman017 is offline   Reply With Quote
Old 03-16-2006, 06:43 PM   #2 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Springs & Struts Guide
I have those KYB installed in my 97 Camry as well. A small improvement over previous stock ones, but then I used about 110k miles on the stock structs. It still feels like the brand new stock ride feeling, but for it's price, it's a great strut.
darksparkz is offline   Reply With Quote
Old 03-17-2006, 11:49 AM   #3 (permalink)
I cant remember where off the top of my head, but I found some strut mounts for 49.99 (front). Would this seem to cheap or...
Also what are these reas stabilizer bushings? I cant seem to find them online
Old 03-17-2006, 02:09 PM   #4 (permalink)
Gameroom cash: $304355
I think you mean "rear swaybar bushings". These are rubber bushings with a slit in them that fit over the sway bar and cushion the swaybar. They keep the metal swaybar from contacting the undercarriage, as the swaybar does it job. There are 2 brackets with 2 bolts each that bolt the swaybar to the undercarriage. The bushings go under the brackets so there is no metal to metal contact. The bushings should be availble at your dealer or any aftermarket auto parts store. The aftermarkets should be around $10 each.
Mike
Old 03-18-2006, 07:04 PM   #5 (permalink)
Mike
I just went to my local auto store, and they wanted $35 apice for the bushings
Another thing, my springs should still be good right?
Old 03-18-2006, 10:40 PM   #6 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
i have the gr2's with my tein h.tech springs.
Your stock springs are good until like 200K, depending on how you drive and where you drive.
Just replacing the struts and the mounts will be pretty darn good. If you have the stock rear sway bar i dont see why you'd need to replace the bushings...but i guess you can if you want to or if they're actually worn out and broken. When i replaced my sway bar a few weeks ago with a thicker aftermarket one, my stock one along with all the bushings seemed just fine to me. I have 91K on my car.
nodrogkam is offline   Reply With Quote
91-93 suspension tamalpro MR2 Forum 1 01-21-2006 09:30 PM
Suspension setup for comfort doru Camry & Solara Lounge 12 04-05-2005 12:52 PM
Suggestions for Replacing Stock Suspension Bensa Camry & Solara Lounge 3 03-29-2005 11:30 AM
replacing 92 camry suspension CronusTRD 3rd & 4th Generation (1992–1996 & 1997–2001) 5 06-02-2002 12:16 PM
