need help please!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 09:37 PM   #1 (permalink)
View 2000LEV6's Photo Gallery
my buddy from other state about to sold he's rims for me and i need help if the rims will be fit correctly on mine is gen 4/2000 the rims brand is nippon racing 17"x7" with bolt pattern is 5x114.3 is that mean 5 lug??
take off from he's car is 2000 eclipse gt.need help if this will be fit on my gen 4/2000 before i sent the money to him.thank you.!!
2000LEV6 is offline   Reply With Quote
Old 03-17-2006, 01:32 AM   #2 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
yes they are 5 lug.
5x 114.3 = lugs x bolt pattern
i dont know if thats the right bolt pattern for a gen4 but i know it is for a gen3 . they will fit mine. most likely they will fit.
project92camry is offline   Reply With Quote
Old 03-17-2006, 01:42 AM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Gen 3, 4 and 5 use 5x114.3.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-17-2006, 02:35 AM   #4 (permalink)
View .tony. .riot.'s Photo Gallery
You need to find out the offset also to see if they will fit your Camry.
.tony. .riot. is offline   Reply With Quote
Old 03-17-2006, 03:37 AM   #5 (permalink)
thank you guys. like JetSpeed said i hope will be fit also. what is offset mean? is that about the tires rubbing at the fender thanks
Old 03-17-2006, 11:37 AM   #6 (permalink)
The offset is the distance from the rim's mounting surface to the centerline.
Old 03-19-2006, 09:15 PM   #7 (permalink)
00 V6 5speed
hester21289's Avatar
View hester21289's Photo Gallery
What offsets will fit a 2000 camry?
hester21289 is offline   Reply With Quote
Old 03-19-2006, 09:52 PM   #8 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
ur rite
skewe is offline   Reply With Quote
Old 03-19-2006, 10:00 PM   #9 (permalink)
i just saw i the back of the rims it said : germany, 17x7 and 38 so i hope the 38 is the offset and hopefully will fit fine on my 2000.also what is the best for look and performances size for the tires between 215/40/17 or 215/45/17 i really want to stay away from 205 cause to low profile and have bad experience in the past!
Old 03-19-2006, 11:03 PM   #10 (permalink)
Yup, it will work on your Camry.
Old 03-20-2006, 02:20 AM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Sounds like 38 is the offset.
You got your tire terminology all mixed up.
1st number = width of the tire.
2nd number = aspect ratio. Its a percentage of the 1st number (width). So 215/40/17 = 40 percent of 215.
3rd number = diameter of tire.
Use this calculator to figure out what size tire you need:
http://miata.net/garage/tirecalc.html
"Skoolin' the unlearned!"
Old 03-26-2006, 12:08 PM   #12 (permalink)
thank's much ! just got my tires from ebay used is michelin pilot HX MXM 225/45/ ZR17 with 6/32nd tread for $80.00 for all 4.yes kind lucky the seller accept my offer summer is coming so is perfect cause i went to tirerack and they said is handle awesome for accellarate and cornering on dry pavement and just oke on wet condition.
now i wondering and hope the tires will fit nicely on the rims without any issues
how much is usualy they charge for mounting and balancing to install it!
