A/C Light Flashes - AC Doesnt work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2006, 06:51 PM   #1 (permalink)
View jrock80's Photo Gallery
2nd Generation A/C Light Flashes - AC Doesnt work
On my 90 Camry when I turn on the a/c it usually works for a while, then after a while of driving especially if you put the gas pedal down more than 3/4 of the way the a/c turns off and then the A/C light on the A/C button starts to flash. It doesnt make any noise or anything else. I had it checked out at the local radiatior/air conditioning shop and they said the system was full of freon, no leaks and that the radiator just needed washed out, it was dirty. They ran the a/c in their shop and it worked perfect. Any ideas?
jrock80 is offline   Reply With Quote
Old 03-17-2006, 08:37 PM   #2 (permalink)
NIGHT STALKER
throwback's Avatar
View throwback's Photo Gallery
well i can help some by telling you the same thing happened to my moms 2004 highlander. i took it to toyota and they said that it was from rain that gets in to the system and it should go away eventually. As they told me that, the next day it went away.
NIGHT STALKER
throwback is offline   Reply With Quote
Old 03-17-2006, 09:03 PM   #3 (permalink)
This doesnt happen when it is wet or dry. Just happens sometimes after you run it for a while or drive it hard sometimes.
Old 03-18-2006, 05:26 PM   #4 (permalink)
I dont know what to do. I dont want to start just replacing parts.
Old 03-18-2006, 05:34 PM   #5 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $910927
iTrader Score: 59 reviews
Why are you running the a/c at the end of winter in Erie Pa?? Wait till its warmer and see what happens then
Its been a mild winter....but not that mild....you that hot?
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 03-18-2006, 05:40 PM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
A/C light flashing means there is a problem with the AC system. Could be the idle up VSV, could be the compressor. Full of gas is it?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-18-2006, 07:29 PM   #7 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I know when I had my first camry, when the a/c light was flashing it was because I had to vacuum out the system and recharge it.
http://www.xclusive.bz
Old 03-18-2006, 07:32 PM   #8 (permalink)
View tarbasd's Photo Gallery
3rd Generation
Started in the same way for me. In a few weeks the compressor started to seize up. My guess is that in my case, the compressor started to give up, so it stopped turning sometimes and clutch turned the system on.
But as it was said before, it can be anything. Flashing light only means there is a problem.
tarbasd is offline   Reply With Quote
Old 03-19-2006, 10:25 AM   #9 (permalink)
I run the a/c sometimes to help when the windows get fogged up. Plus I have always been in the habit of running the a/c once in a while in the winter anyway, it helps keep the system lubricated. This way the a/c hasnt been sitting for months unused. I am hoping its not the compressor, that sounds expensive, especially with the old type of freon in there.
Old 03-19-2006, 12:50 PM   #10 (permalink)
View The Car Newbie's Photo Gallery
it could your freon. sometimes if a cooling system doesnt have enough freon then it will work for a little bit then not work. most cars now use R34 Freon
The Car Newbie is offline   Reply With Quote
Old 03-19-2006, 07:42 PM   #11 (permalink)
I had the freon checked, it was full and had good pressure. So its not that.
Old 03-20-2006, 03:33 PM   #12 (permalink)
Gameroom cash: $304355
Check the tension on the a/c belt and the condition of the belt itself. Is it glazed? If the belt slips, it will turn the compressor off and the light will flash. I had this problem on an 86 (generation 1), once in a while during heavy rain storms. It seemed that water would get on the belt and pulley combination and cause it to slip. The compressor would shut down and the light would start flashing. The fix for me was to stop and shut the car off and restart it and turn back on the a/c. It only happened about once a year, so I never really bothered changing out my belt.
Mike
Old 03-20-2006, 03:44 PM   #13 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
I know in my mom's Avalon the belt was stretching out and just loose enough to slip a little when the gas was punched and it would ocassionally make the light flash. It has also had the issue in heavy rain if enough is splashed up underneath the car. Hopefully its a similar problem as a new/tightened belt is an easy fix.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 05-21-2006, 10:42 PM   #14 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Exclamation
Sorry, but the only experience I have w/ this type of problem was w/ my 1985 Camry (w/ the I4).
The A/C light was blinking when I tried to run the A/C. I had to install a new RPM sensor into the compressor. It was a PIA, since the system needed to be opened.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 05-21-2006, 11:07 PM   #15 (permalink)
View marc780's Photo Gallery
What Mike G. said, check the belt. Maybe it is loose or slipping or worn out. What makes me say that is you mentioned it varied with gas pedal postion, which indicates to me engine speed difference, and the A/c compressor is driven by the engine..so it might just be a belt problem
Also try cleaning the front of the radiator fins and the evaporator (which is sort of like a mini radiator in design). Maybe they are full of dirt. Blow them out from behind with low-pressure water or air. if they are clooged with dirt this could interefere with their operation, for sure.
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
brake light doesn't work when headlights are on 99mustang232 89-95 Toyota Pickup/Hilux 8 05-31-2006 11:38 PM
corolla 94 AC belt A/C dmp Hardcore Tech and Competition 0 06-20-2004 10:34 AM
Will automatic AC climate control unit work on mine? Jay Camry & Solara Lounge 2 06-12-2002 08:16 PM
