Whiteline RSB Owners: Slick Surfaces?
I found the following quote on the Tokico web site.
Anti-roll or Sway bars
A suspension does not have to have anti-roll bars, however they are quite common on many vehicles. The anti-roll bar is designed to help reduce body roll or lean. By using anti-roll bars, vehicle manufacturers are able to reduce spring stiffness. Softer springs improve ride quality and they help adhesion in many situations.
Anti-roll bars can also be used to improve handling balance. However, bars that are too large (too stiff) can reduce adhesion on slick surfaces. This is especially true on snow and ice. They can also be a disadvantage for serious off-road driving.
Have you had any problems with slick surfaces after adding a Whiteline RSB?
Thanks!
Chasman
202k one-owner
87 I4 Camry Wgn
ES250 Strut Brace, Tokico Blue, Ceramic pads
Falken ZE-512, Goodyear Eagle UltraGrip H-rated M&S
