engine noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2006, 01:22 AM   #1 (permalink)
325
View 325's Photo Gallery
engine noise
Getting some noise from beneath timing belt cover.Goes away at 2k rpm and above.2000 Camry CE.
Any ideas what it could be?
325 is offline   Reply With Quote
Old 03-19-2006, 11:23 AM   #2 (permalink)
325
It's a sort of "growling"noise that rises and drops with the rpm's.
Anyone had similar problems?
Thanks!
Old 03-19-2006, 02:08 PM   #3 (permalink)
View extoytech's Photo Gallery
Water pump
extoytech is offline   Reply With Quote
Old 03-19-2006, 05:55 PM   #4 (permalink)
325
Thanks extoytech!
I'll get a Haynes manual and check it out.
Old 05-06-2006, 12:03 PM   #5 (permalink)
View blueapple's Photo Gallery
no it's not, it's the timing belt hitting the timing belt cover, it goes away at exactly 2k rpm, has nothing to do with the water pump.
It's either a loose belt after years of driving, or a worn tensioner bearing.
Mine did that for half a year now, it's very common in camrys, change them out if you can, or check your belt regularly
blueapple is offline   Reply With Quote
Old 06-02-2010, 06:54 AM   #6 (permalink)
View IBJIBN1's Photo Gallery
Hi..Was the "growling" noise you mentioned kind of like a RRRRRRRrrrrrrrrrring nose? I does sound like it's coming from under the timing belt...the sounds goes away over time and it sporatic.
my 96 Camry has 87K.
Wonder if it's time for a new timing belt.
Thanks
IBJIBN1 is offline   Reply With Quote
Old 06-04-2010, 08:48 PM   #7 (permalink)
manual says to change at 60k ( if it's the original belt ) newer belt are said to last till 90k. There's a revised pre-tension spring too. Sadly these engines don't have hydraulic tensioners.
I had a water pump go on me as well, but that noise doesn't disappear after certain RPM.
If yours is there all the time and doesn't sound rhythmic, I say check the water pump.
Old 06-04-2010, 09:08 PM   #8 (permalink)
Drove to the Dark Side
JayP71's Avatar
View JayP71's Photo Gallery
Just a note. If you wind up replacing the timing belt, just replace the water pump at the same time, it's driven by the timing belt, and it will save you a lot of trouble down the line to just do 'em both and be done with it.
JayP71 is offline   Reply With Quote
Old 06-05-2010, 05:55 AM   #9 (permalink)
camry engine noise
Is the "belt tensioner" something that can be changed without changing out the belt?
Thanks
Old 06-05-2010, 11:05 AM   #10 (permalink)
JayP71's Avatar
Thanks
Yes, but the belt has to come off to get it off. Why put an old piece of rubber back on? Especially when you consider the frustration and expense of a broken timing belt.
Engine Noise 1996 Tacoma 2RZ-FE :( chipsndukes 1st Generation (1995.5–2004) 20 08-21-2010 08:14 PM
engine noise? image Camry & Solara Lounge 5 05-03-2005 01:53 PM
my Camry 03 makes loud noise from engine room! poraminna 5th & 6th Generation (2002-2006 & 2007-2011) 6 02-23-2005 09:19 PM
Engine noise after parked my 04 Corolla bluemm Archived Corolla threads 9 11-22-2004 09:15 PM
Engine Knocking/tapping noise in gen2 camry?? smt_007 1st & 2nd Generation (1983–1986 & 1987-1991) 6 11-11-2003 05:55 AM
