3sgte ecu swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2006, 07:44 AM   #1 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
3sgte ecu swap
can i wire in a 3sgte ecu into my car since it already knows what to do with boost?
i'm still going to use my 5sfe motor but i want to use the 3sgte ecu. is there anything stopping me from doing that?
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 03-19-2006, 08:42 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Why would you want to do that? Surely they'd be mapped differently?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-19-2006, 08:43 AM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the pinouts and wiring are different
Old 03-19-2006, 09:11 AM   #4 (permalink)
Mad Scientist
to clarify: the 5sfe engine is an economy engine with an na setting for the ecu
the 3sgte engine is a performance engine with an fi setting for the ecu
they are for the same family of engine and the pinouts wouldnt be a problem.
Camry Wagon Crew
Old 03-19-2006, 09:31 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
ya sure about that?
Old 03-19-2006, 10:59 PM   #6 (permalink)
Gameroom cash: $368676
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
You should be able to keep your 5sfe one. Once you're boostin, get a 3sgte ems. I mean, 3sgte base boost shouldn't be too much more than 7psi that the engine can already handle
RichieRichJP is offline   Reply With Quote
Old 03-19-2006, 11:21 PM   #7 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
It would not work based on the fact that the ignition system is totally different.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 03-20-2006, 07:43 AM   #8 (permalink)
VeeZed
I completely disagree with everyone except Fred....it will not work!! You cannot just put an ecu from another engine, with COMPLETELY different mappings and expect it to work...even if you did customize the pinout!!! It's like me trying to put a 5VZ-FE ECU into m 2VZ-FE powered car because the 5vzfe is "larger" and would accomodate more fueling...not gna happen!
Old 03-20-2006, 08:06 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Well their both S series engines, but they are different.
You can't just slap on a ECU for a different motor and expect it to work with your motor. Even if you did get it to work, the fuel & ignition timing maps would be wrong.
Both motors have different fuel requirements, ignition timing, and airflow characteristics.
You want to play with ECUs and tuning, buy a aftermarket standalone.
"Skoolin' the unlearned!"
Old 03-20-2006, 04:30 PM   #10 (permalink)
View mike7869's Photo Gallery
if u do want to go through with it.. even though it won't work.. i have an ecu i can buy of a mr2 turbo.. 94ish... but i don't think it will work...
mike7869 is offline   Reply With Quote
Old 03-20-2006, 04:39 PM   #11 (permalink)
Mad Scientist
ok close this thread i got my answers i will have to go the otherway
Camry Wagon Crew
Old 03-20-2006, 05:24 PM   #12 (permalink)
I plan on running a stock map on a standlone AEM EMS for the 3sgte on a stock MAP until I get dyno tested and boosted. Since everything is fully programmable, there shouldn't be any problem of this kind on a 5sfe ecu should there? I'm just wondering what I should do about the OBDII...
Old 03-21-2006, 02:13 AM   #13 (permalink)
Grenaded piston
88 LE's Avatar
Well if your using a standlone ECU, the stock one goes bye bye. You don't use the stock ECU anymore.
There shouldn't be any problems other then getting it installed, working, and tuned.
OBD-II will not work, as your no longer using the stock ecu.
Old 03-21-2006, 06:34 AM   #14 (permalink)
Yes thank you! My evil plans will work after all muhahaha
Old 03-21-2006, 02:07 PM   #15 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
Crank triggering will be a problem if the AEM is set up for the 3s-gte and you use it on the 5s-fe. Good luck, I hope you or your shop are REALLY good with wiring/electronics and custom work.
-Charlie
white90dx is online now   Reply With Quote
3SGTE swap or 3SGE akujin MR2 Forum 9 05-17-2007 06:15 PM
mr2 n/a to 3sgte swap Fareal619 MR2 Forum 1 01-12-2006 12:48 PM
3sgte engine swap vs 1mzfe turbo KamryStylez 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-08-2005 12:59 PM
3SGTE Swap on an '03 Flea Archived Corolla threads 11 09-22-2004 07:53 PM
