oil change question?
I have a camry 6cyl 98 191,474 on it, I reg. take it to jiffy lube or any place to give it oil change. Yesterday I did an oil change on it I use syentenic blend oil 10-30, but on the oil cap on the car says 5-30 is this going to be a problem.
I wanted to use syntenic oil but auto zone says that syntenic oil is only good if you started out using syntenic oil on the car if I change it to syntenic oil it will find week point and start leaking oil.. is this true? they say that it is okay to use syentenic blend oil that is what I am running in my car right now..
BLk Camry 98-6cyl 1mz
