Help! Transmission stuck in Park - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2006, 01:35 PM   #1 (permalink)
View bigphil001's Photo Gallery
My transmission recectly decided that it didnt want to come out of park unless I push in the "Shift Lock Overide" button in. I have a 1992 Camry LE, with 148000 miles on it, any help fixing this problem would be appreciated. Thanks!
bigphil001 is offline   Reply With Quote
Old 03-20-2006, 02:16 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
First thing you should do is check your fuses.
check the brake light switch under the dash. It is basically a plunger type switch taht actuates when you step on the brake pedal.. Youcan do a quick check by looking to see if all of your brake lights are working. If only one of the em is out then it is not the switch. If all of them are out however then you probably want to start there.
Another thing is the actual solenoid that unlocks the switch in the console. THey are bad about going out when any kind of liquids are spilled into it.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 03-20-2006, 04:50 PM   #3 (permalink)
THanks, it was actually the solenoid going bad, appreciate it!
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Gear selecter stuck in park 4runlou 4Runner Lounge 3 03-21-2006 10:50 PM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
stupid stuck transmission - HELP, Please! 89alltracAuto Camry & Solara Lounge 2 02-07-2004 05:26 PM
