trany swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2006, 04:07 PM   #1 (permalink)
View mike7869's Photo Gallery
trany swap
i am about to order a manual trany for my 95 camry wagon with the 5sfe, i have the clutch peddle and the cylinder, but i was wondering if the flywheel will bolt right up instead of the flex plate or is the bolt pattern differ.. i know it uses differ bolts tho.. and a 99 trany should work with the 92 - 95 engine.. bc the engine did not change untill 2001.. and all the contectors and speed sensore should hook right up right? anything else i should look out for or change.. i have done engine and trany pulls before...
mike7869 is offline   Reply With Quote
Old 03-21-2006, 02:26 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I believe you also need the brake pedal as its smaller on a manual vs. automatic.
Which tranny are you getting and which car is it from (yr, model, engine, etc..)?
Depends on the flywheel. If its from a 5S-FE with manual tranny, it'll bolt up.
There may be flywheels from other engines that work, but I'm not sure.
If the flywheel is in good condition, have it resurfaced. Replace the clutch assembly (clutch disc, pressure plate, and throwout bearing).
Might want to also look into new shifter cables and slave cylinder.
"Skoolin' the unlearned!"
Old 03-21-2006, 04:00 PM   #3 (permalink)
the trany is a 99 trany from a camry with a 5sfe... the trany has about 30k.. should i still have that flywheel resurfaced from that trany should i even replace the clutch, it only has 30k... i know i should look at if first when i get it.. everything else is taken care of.. all i need to do is rewire the trany conect so it thinks its in nutral and put in the trany
Old 03-22-2006, 03:20 PM   #4 (permalink)
ok.. i have another ? do i need a differ starter bc of the fly wheel thikness... and i have a master cylinder of a mr2 it should work right.. ook.. another ? last one.. this is stupid but does the trany usaully come with a slave cylinder...
trany swap: Does the Paseo 4sp overdrive automatic fit onto Tercel 3EE ? tercel_maniac Tercel, Paseo, Starlet, and Sera Forum 6 10-13-2006 11:09 AM
4age 20v vs b18 swap good_old_geo Archived Corolla threads 15 08-28-2006 07:37 PM
20V Swap, can someone help? -HiTMaN- Archived Corolla threads 8 02-24-2006 05:02 PM
3EE to 5EFE engine swap DaBomb77 Tercel, Paseo, Starlet, and Sera Forum 2 08-20-2005 10:51 AM
ATTN: speedemn - Yoshio Engine Swap Ratko Camry & Solara Lounge 4 12-28-2001 04:22 PM
