Originally Posted by terrastrife
even if it was possible to convert to a distributor (not sure, i have a 3vz :P), the ecu will no longer be able to control it and you will end up needing a standalone anyway =)
I have a 5SFE. I do not think that a standalone is necessary though, If I grabbed a ECU to match the head that has a distributor then it should work fine right? Basically I would chop the ECU and connector out of a 94 Camry, grab the head or possibly just dizzy, wires, igniter, coil and then rewire my wiring harness to fit the plug that plugs into the 94 ECU which of course is meant to run that particular engine with a distributor. The blocks are basically identical its just the ignition system that is different. Then I wire a MSD BTM in with the igniter and I can retard timing per pound of boost without having to retard timing across the whole range (base timing). I can get an ECU for $50, whole head with dizzy, igniter, coil and wires for $150. Why would I need a standalone?
