Trick for replacing strut rubber bushing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2006, 08:38 PM   #1 (permalink)
Official TN member
View tracyf's Photo Gallery
I recently did both of my front struts on a 1990 Camry and the rubber bushings at the bottom were all worn through and deteriorated to the point that I could not see re-using them. I at first thought of maybe going to where they put tires on big trucks and see if they had any refuse inner tubes I could cut some pieces out of, but then a much simpler and better idea hit me. I went to AutoZone and bought me a few feet of 1/2" heater hose. I took a length long enough to make the first complete circle at the bottom of the spring, cut into it along the top side running longways the whole length, then pushed it onto the spring to where the spring entered the slice I had made in it. What I ended up with (sorry for not taking pictures) was a piece of rubber lots thicker than the original bushing that completely covers the bottom of the spring with the exception of the slit at the top of the hose. This ought to last as long as the steel spring does. I hope this helps someone else out there - we all have to share our brainstorming - right?
God Bless.
www.tracystruesoaps.com
tracyf is offline   Reply With Quote
KYB ( any non OEM ) Strut mount for Gen3 Camry? Front? blueapple 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-26-2008 11:36 PM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
Rear Strut Broken. Need Help. 3vz4me Camry & Solara Lounge 3 06-13-2005 12:29 AM
Changing out strut mounts and spring bumpers - Advice needed (4th Gen Camry) Bob_98SR5 Camry & Solara Lounge 6 03-01-2004 07:17 PM
TRD strut Tubbyc Camry & Solara Lounge 3 07-02-2003 02:22 PM
