startup idle speed?!?!?!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2006, 09:38 AM   #1 (permalink)
View MattSWE's Photo Gallery
2nd Generation startup idle speed?!?!?!?!
hey all, I just have a quick question about my gen 2. Every now and then whenever I start up the camry after a minute or two the engine will rev automatically up to 2500 rpm and stay there, then sometimes it will rev then go back down and rev then go back down for at least a few minutes. What could the problem be? Is my automatic choke messed up? I have no idea.
MattSWE is offline   Reply With Quote
Old 03-22-2006, 12:51 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
sounds normal mine doesn't quite go that high it goes to about 1500ish range then then it slowly goes down... try cleaning the AIC along with the throttle body
Old 03-23-2006, 08:52 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
It all depends on how cold it is outside.
In warmer climates (say, above about 45*F) high idle is 1500-1900rpm.
In colder climate (below freezing-ish) high idle can be over 2000.
Just start the car and drive slowly/carefully until the idle goes down to the normal warm idle. Everything sounds fine to me.
-Charlie
white90dx is online now   Reply With Quote
Old 03-24-2006, 06:19 AM   #4 (permalink)
View Gary_602Z's Photo Gallery
No it is not normal! A higher idle when cold is normal but it should not be idling down and then reving up on its own. Check the IAC.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 03-24-2006, 06:22 AM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
the IACV is probably dirty. the ecu controls this valve but when the valve cannot open/close to the requested amount, then things start going all over the place. If cleaning this doesnt resolve your problem, try adjusting the idle adjustment screw.
terrastrife is offline   Reply With Quote
Old 03-25-2006, 07:00 AM   #6 (permalink)
tmg
View tmg's Photo Gallery
My Mum's car did this, today and it was NOT normal!
What is this AMI/IAM Valve thingy and where can I find it? I can clean my mum's car if I can find it.
Did that make sense??? Anyway, just tell me where this valve is...
tmg is offline   Reply With Quote
Old 03-25-2006, 08:54 AM   #7 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
Calm down, first you need to tell us witch engines your car has (I4 or V6)
or else we cant you tell where the IAC valve is, what temperature it
was when this happend?, and what car does your mom have?
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Old 03-25-2006, 10:11 AM   #8 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Check all your sensors, air, coolant, etc.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 04-11-2006, 05:41 AM   #9 (permalink)
tmg
My mums car is a 1991 toyota camry executive wagon with an I4 2Litre engine, standard intake components and tonight (11th Arpil) I was reversing down the driveway and it felt like it was going to cut out something chronic. I got really ticked off at it...
...if anyone on here lives on the sunny coast in queensland and knows about Kmart Tyre and Auto can you tell me if they're any good coz that's the place that last performed the service on my mums car...it gets progressively worse.
Old 04-11-2006, 08:33 AM   #10 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
2500RPM is too high....
Toyota specifies 1500-1800RPM
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 04-11-2006, 08:57 AM   #11 (permalink)
The 6"4 Viking
Zandro's Avatar
Mine usualy stays around 1500-1700 (depending on the temp) for 3min and then
starts to drop down as the engine gets warmer. 2500 is too much, you probably have
a broken temp sensor.
Old 04-16-2006, 12:09 AM   #12 (permalink)
tmg
All fixed! replaced the dizzy cap and leads with a new kit from SCA and it goes a lot better, doesn't even make a rattling sound when going up hills according to my mum.
Also don't go to KMart Tyre and Auto, those guys are wankers to me, they didn't even clean the air filter and box when they last serviced my mums car.
> How much power gain do you get if you chop the bottom of the air box off? coz the standard "snorkel" is too small!
Old 04-16-2006, 01:45 AM   #13 (permalink)
VeeZed
Also don't go to ............, those guys are wankers to me, they didn't even clean the air filter and box when they last serviced my mums car.
50kw....RE!
And remove your comment about the "store" you went to that didnt cleanthe airbox... you can't bash a store because some idiot mechanic that happens to work there is an numnut. A friend of mine is a mechanic at one of those stores..and he is bloody awesome!
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Idle speed too high upon start up... how to fix??? highlander04 General Discussion 21 01-30-2007 01:43 PM
Tire suggestions? Vaipunk Archived Corolla threads 11 03-11-2005 06:48 AM
88 Supra Idle Speed Motor ratnin57 Supra Forum 13 09-26-2004 04:22 PM
Strange Idle Speed terrynham Camry & Solara Lounge 4 03-06-2004 12:52 AM
