QUESTION check engine light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2006, 03:20 PM   #1 (permalink)
View trickyazn's Photo Gallery
4th Generation QUESTION check engine light
ok the codes for my gen 4 01' 5sfe are the usual retarded evap codes everyone gets (P0440 Evaporative Emission System, P0441 Evaporative Emission System Incorrect Purge Flow, and P0446 Evaporative Emission System Vent Control Circuit) well the thing is if we dont do anything to the engine.. will it matter? does it cause bad gas milage? hard your engine? what im basically wondering is if its actually necessary because my car runs fine.. so yeah.
trickyazn is offline   Reply With Quote
Old 03-22-2006, 04:35 PM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
It basically means your evaporative system wont work. It will not have any effect on the way your engine runs, assuming the malfunctioning vsv(s) are stuck in the closed possition. Of course you will have no chance of passing the emission test.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-22-2006, 04:56 PM   #3 (permalink)
View freeyellow2000's Photo Gallery
doesn't this affect mileage
freeyellow2000 is offline   Reply With Quote
Old 03-22-2006, 05:09 PM   #4 (permalink)
View Gary_602Z's Photo Gallery
Probably not but the problem comes in if the engine throws a code such as a random missfire that could cause problems(such as burning the cat out) then he would not know because he is used to the light being on all the time.
Best bet is to get it fixed now before you have more/bigger problems!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
Traction Light with P0135 check engine code fincobbler Solara 8 05-01-2008 07:51 AM
Check Engine Light Question jbirdy958 Camry & Solara Lounge 4 03-15-2006 06:28 AM
Traction Light with P0135 check engine code fincobbler Solara 1 02-17-2006 08:50 PM
Noob Check Engine Light Question Boulder257 Celica Forum 13 09-06-2004 01:12 AM
