Hey all. As you can probably guess, I'm new around here. I've been lurking around for quite awhile until I finally decided to register and make myself known to the community. As you can tell from my sig, I have a '95 Camry LE, and I was wondering if these headlights: http://www.andysautosport.com/produc...54&_v=vmd00391
will work for my car. It says for 92-94 Camrys, but I was under the impression that 92-96 was all the same body style. I was also wondering if anyone else had any experience with these particular lamps and whether quality-wise they are any good or if you would recommend something else.
Thanks a bunch guys!
__________________ ~//1996 Corolla DX - 1.8L - white - Scion rims - short ram - urethane mounts - hitch\\~
Not without getting a new grille at the very least. 92-94 and 95-96 have different headlights. The picture in the link appears to be broken, but I'm guessing it's the crystal clear headlamps that quite a few people have. They're not bad. Gives your car a real clean look, but don't expect any increase in output unless your stock headlamps are really fogged up/dirty/yellowed.
1994 Camry 2.2L LE Auto
Like DarkMastyr said the 92-94 are different than the 95-96. If you look taht the headlights the inside edge of the early ones are squared off. The older ones come to a point at the grill. SO without changin the grill and some other stuff you cant use those headlights. There are some people on here tha have done it and it looks good afterwards. I think RedPheonix did the conversion. Maybe he will chime in. Or anyone else that has done the conversion for that matter.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Thanks for the replies guys! I figured there must be something up with those lights. It never can be that easy, can it (at least not for Camry owners <img>)? I guess if we all drove Civics we would just be that much lazier though, eh?
What kind of headlights did you get? Depo for your 96 camry? ???
I bought the '92-'94 ones. I have a '96 but the front end is from an '92 or '94. The car had been in a frontal collision and they guy who fixed it just put a gen 3 front end.
it will look the same as a gen 3 because he has the whole gen 3 front end now.
as for you youll probably want a new grille and youll also need a few zipties as the mount locations have changed slightly between the years.
