Where is the fule pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2006, 11:49 AM   #1 (permalink)
View The Black Camry's Photo Gallery
I have a 90 camry and i was just wondering, where is the fule pump? and how do i get to it?
The Black Camry is offline   Reply With Quote
Old 03-23-2006, 11:54 AM   #2 (permalink)
View YYY Camry's Photo Gallery
The fuel pump is inside the fuel tank, I've see fuel pumps around $80 and $100 on the net, don't know exactly what fuel pump is best for your car, should ask a mechanic or someone in the forum might know. Later
YYY Camry
YYY Camry is offline   Reply With Quote
Old 03-23-2006, 12:02 PM   #3 (permalink)
ok, thanks but how do i get to it?
Old 03-23-2006, 12:05 PM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
take off the rear seat.. the part where u sit on no where your back goes.. there's 2 clips under the seat push it in and pull the seat up.. just feel around for em it's hard to miss.. it's on the edge where the seat and the floor met.... then there's 3 screws and some wires you'll see .. that's em right there
Old 03-23-2006, 12:07 PM   #5 (permalink)
Tom 2000's Avatar
Gameroom cash: $201300
View Tom 2000's Photo Gallery
On most cars, if you remove the rear seat cushion, you'll see a something like a round metal plate. It's inside there.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 03-23-2006, 12:28 PM   #6 (permalink)
oh ok thanks guys!
Old 03-23-2006, 06:27 PM   #7 (permalink)
Banned
View BlackPearl's Photo Gallery
i just receive my 255 walbro today and i wanted to see where my stock one was...its under the bottom of the back seeat (part u sit on) cusshion...remove that...theres only clips holding it in so just pull up and out...ull see a metal plate cover with like 5 or more screws...unscreww and ulll see wires and fuel feeds coming out of a second sealed cover...relieve pressure from the gas tank by simpley unscrewing the gas cap from wher eu usually put gas...then go disc the feed pipe...ones a nut feed and other is a clamp on...unscreww the screws holding this plate down and lift....havea rag hand..the fuel pump will be cover in gasoline..hope this helps...
^^ on my gen 3
BlackPearl is offline   Reply With Quote
Old 03-23-2006, 06:29 PM   #8 (permalink)
Carzz R Xpensive!!111
felkajamine's Avatar
iTrader Score: 11 reviews
View felkajamine's Photo Gallery
you cna get to it from underneath your car i thought. you would need a car bay for it probably, or a car lift!
didn't know you could get to it from under your back seat sounds a little easier, maybe!
'95 5spd Scepter Coupe
felkajamine is offline   Reply With Quote
Old 03-23-2006, 11:40 PM   #9 (permalink)
Sebastian Loebs evil twin
BakaWill's Avatar
View BakaWill's Photo Gallery
it sits inside of the fuel tank to get to it from underneath you would have to drop the tank. and you probably wouldent be able to remove the tank without bending the hardline or somethin so getting to it from the backseat is unbeliveably easier
1990 camry dx 3s-fe
BakaWill is offline   Reply With Quote
Pay Before You Pump... RANT epinionator89 Off Topic 69 08-28-2006 09:37 PM
Window Washer Pump Replacement ciw Previa Forum 1 02-10-2006 10:18 AM
Walbro Fuel Pump, turbine pump? almc2242 Hardcore Tech and Competition 13 02-19-2005 09:08 PM
