Speaker install help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2001, 12:04 AM   #1 (permalink)
View CAM+REEE's Photo Gallery
hi i drive a 92 camry le
i wanna change the two front speakers but i dont know how to get the door panel off I DONT WANNA SCREW SOMTHING UP!
please help me out thx guys
- nik -
CAM+REEE is offline   Reply With Quote
Old 07-30-2001, 03:32 PM   #2 (permalink)
can somone please help me out i really wanna get those speakers out of my car
THX
-nik-
Old 07-30-2001, 10:24 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Considering I just spent 3 days ripping my car apart ( http://www.tt-cc.com/forum/viewtopic.php?topic=128&forum=1&12 ) I feel I can advise you with confidence.
It's pretty simple with a few tricky parts.
1-take off all screw. 2 by the hinges (covered with plastic caps), 2 in the door handle (cvrd with plastic plugs), 1 buy the door pocket, 1 behind the door courtesy light, 2 small screws along the bottom, under the panel.
2- pop off the 2 "snap" things by the lock assembly. Use a screw driver to "pop" the center "button" inwards then pry them out.
3- here's the tricky part. BE CAREFUL! removing the door handle bezel. It's snapped in place VERY tight. gently pry the front out a bit, then pry the top down, then pry the bottom up. Once you have it sort of out, carefully force it towards the "back". TAKE YOUR TIME! I broke mine the first time.
4- The rest is easy. Gently snap off the bottom area of the panel and work your way around. To remove it off the door lift it in an upward motion.
Hope that helped! If I wasn't clear, let me know
_________________
"Good Enuff 2B a Taxi, Good Enuff For Me!"
'92 Camry V6
-Clear Tails/Bumper lights
-Tokicko + H&R
<font size=-1>[ This Message was edited by: Phi on 2001-07-30 23:31 ]</font>
<font size=-1>[ This Message was edited by: Phi on 2001-07-30 23:32 ]</font>
Phi is offline   Reply With Quote
Old 08-01-2001, 12:41 AM   #4 (permalink)
What exactly to u mean &quot;gently force it backwards&quot;??????????
and how to i get the buttons that roll the window down off?
Thx
-nik-
Old 08-01-2001, 01:36 PM   #5 (permalink)
PHI r u there i have all day today and i really wanna get this done
im having trouble with the door handle thingy it wont come off
how to i get that FUKKER out thx
-nik-
Old 08-01-2001, 02:05 PM   #6 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
The door hadle bezel is held in by pegs on the bottom and top. What I mean by &quot;back&quot; is the direction (towards the &quot;back&quot; of the car) Once you've got the front, top and bottom of the bezel sort of loose, use the heal of you hand to force it out in a &quot;backwards&quot; direction. It's held there with a hook.
As for the power lock and windows connections , they're just held together with plastic tabs. Use you fingers(if they're small enough) or a screwdriver to press the tabs down and pull the connectors apart at the same time. Don't get frustrated, that's how I broke mine. Just play around with it and it should come loose.
BTW I'll be here for a while (6 hrs @ work). Let me know if you need any thing else.
_________________
&quot;Good Enuff 2B a Taxi, Good Enuff For Me!&quot;
'92 Camry V6
-Tokicko + H&amp;R
<font size=-1>[ This Message was edited by: Phi on 2001-08-01 15:15 ]</font>
Old 08-01-2001, 02:19 PM   #7 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
Just in case it still doesn't work, I'll try to help you out more. Use a flathead screwdriver to pry the top and bottom off. Gently, yet with some force push it towards the &quot;back&quot; of the car while your trying to free up the top and bottom. Playing around with the handle itself may help to (open and closing motion)
_________________
'92 Camry V6
-Tokicko + H&amp;R
<font size=-1>[ This Message was edited by: Phi on 2001-08-01 15:42 ]</font>
Old 08-01-2001, 02:48 PM   #8 (permalink)
phi does the little lock knob and handle come off too or just the plastis around it?
and i still cant get it off
i managed to get the top of it loose but the rest wont budge at all. Did u have this much trouble?
and i got the window thingy off with no problem so thx for helpin me out there
and how do i remove the curtosy light? does that just pop off as well?
thx
Old 08-01-2001, 03:12 PM   #9 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
Just the plastic around the handle comes off. The handle is fixed on the door itself. Yes I did have as much difficulty as you . I use my broken one as a guide to help me take that thing off. But it's still hard everytime I do it.
The courtesy lights just pops off, no screws.
_________________
'92 Camry V6
-Tokicko + H&amp;R
<font size=-1>[ This Message was edited by: Phi on 2001-08-01 16:13 ]</font>
Old 08-01-2001, 05:10 PM   #10 (permalink)
ok i will let u know how it goes tomorrow
thx Phi
-nik-
Old 05-08-2002, 06:41 PM   #11 (permalink)
RUN WHAT YOU BRUNG
View 92CAMRYGTS's Photo Gallery
damn guys you 2 seemed like you had a lot of trouble. when i had my widows tinted the guy took off my door panels. he did it 1-2-3 with no probs at all. it obviously isnt that hard to do but i guess if its your first time to do it it wil be a pain in the ass. good luck. and just think after you figure out how to do it you can charge other camry people that want their speakers changed.
92CAMRYGTS is offline   Reply With Quote
Old 11-05-2004, 03:20 AM   #12 (permalink)
View Pier5215's Photo Gallery
http://www.toyotanation.com/forum/re...871&i=91671751
This is a good site, tells you exactly how to take the door off
Pier5215 is offline   Reply With Quote
Old 11-05-2004, 03:22 AM   #13 (permalink)
Sorry - wrong link! This is the right one
http://autorepair.about.com/library/.../aa092504b.htm
Old 11-05-2004, 05:34 AM   #14 (permalink)
Big Wrench
View Mikey21's Photo Gallery
Pier5215,
Wow, You're good!
You can actually bring dead back to life.
Look a the thread dates to the left. It's been dead 2 1/2 years wow you're really good.
Old School Wrench/ New School Ride
My Camry Pic's
Mikey21 is offline   Reply With Quote
98 Camry Rear Speaker Installation problem ! Help !!!!! 98Toyozip 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-07-2008 08:41 PM
'83 Celica GT Speaker Removal/Replacement Warped Celica Forum 4 10-27-2002 01:52 AM
factory speaker grille IrishGuyute1 Camry & Solara Lounge 20 07-23-2002 04:01 AM
amp install help camryLI Camry & Solara Lounge 16 05-02-2002 07:42 PM
a speaker question gen4cam Camry & Solara Lounge 6 10-31-2001 07:12 PM
