One headlight burnt out, replace both or just one - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: How many bulbs should I replace?
One- cheaper but maybe not safe 5 29.41%
Two- more expensive 12 70.59%
Wait till i get a ticket for burnt out bulb 0 0%
Voters: 17. You may not vote on this poll
Old 03-23-2006, 08:35 PM   #1 (permalink)
View solidg's Photo Gallery
I ve heard various opinions on this. My passenger low beam light burnt out.
Do you think I should just replace the one bulb, Ive heard that this isnt safe.
Or replace both the bulbs, even though its more expensive.
00 camry le v6 94k
solidg is offline   Reply With Quote
Old 03-23-2006, 08:43 PM   #2 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
if someone told you that it isnt safe, why would you still want to do it then?
of course do both...
bulbs dont even cost that much, unless you got HIR's or Silverstars
WhiteRabbit is offline   Reply With Quote
Old 03-23-2006, 08:51 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I doubt that it's unsafe. I think it would just be more convenient to replace both at the same time because when one goes, the other will soon follow.
Get a set of Sylvania XtraVision bulbs. $9-$10 each or sometimes they're sold in pairs for $19 or $20. Slight improvement over stock bulbs.
2007 Camry 2.4L 5M
Old 03-23-2006, 09:01 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140895
why would it be unsafe?? i always replace them one at a time because i never have both go out close to the same time. i just dont see the need to replace something that is working just fine.
Old 03-23-2006, 09:36 PM   #5 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
It's not that much more expensive to go with 2 anyways. Plus if you mix a old one and new one, the newer one might be brighter then the older one, so you might see a bit of a difference
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 03-23-2006, 09:39 PM   #6 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
Exactly what I came in here to say, but you said it already so I'll just walk back out.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is online now   Reply With Quote
Old 03-24-2006, 03:44 AM   #7 (permalink)
View karazy's Photo Gallery
I buy the set and if I can't see a diff in brightness, I just put the extra in the glove box. I change them both on the Taco, because I have to take the grill off to change them.
karazy is offline   Reply With Quote
Old 03-24-2006, 01:21 PM   #8 (permalink)
Put silver stars in there. Wow what a difference! The light is white instead of yellow. It so much better. I replaced both of them. Thanks for the replies.
Old 03-24-2006, 01:38 PM   #9 (permalink)
97 Camry
View Davee's Photo Gallery
4th Generation
If you use the car a lot at night the premium Silverstar or equivalents are a good move . Just keep old bulb that is good for emergency. It is not unsafe to change one Who gave you that BS?
Davee is offline   Reply With Quote
Old 03-24-2006, 02:44 PM   #10 (permalink)
TN's furry friend
i guess they meant unsafe as in the other one could go and youd be driving with one headlight
how to replace headlight bulb toyota corolla? toyotapad Archived Corolla threads 5 11-08-2011 08:43 PM
How do I remove the Headlamp housing on a 92 Previa? breitsd Previa Forum 2 01-18-2006 10:15 AM
replace the headlight assembly vlcamryLE Camry & Solara Lounge 3 09-14-2005 08:16 PM
replace burnt out tail light? bout Archived Corolla threads 4 07-18-2005 11:12 AM
