broke off bleeding screw. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2006, 10:10 PM   #1 (permalink)
View userid's Photo Gallery
i managed to break off the bleeding screw, so half of it is still stuck inside the caliber. Does this mean i need a new caliper? If i do, how much does it cost? i have a 99 camry 4 cyl.
userid is offline   Reply With Quote
Old 03-23-2006, 10:25 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
uh oh...you just might, since hte screw is kind of small to drill and tap to get out...
is there even any little bit left sticking out? if there is, you can use a set of pliers to get it out eventually....
and a rebuild caliper usually costs around $100, some a bit more expensive
HaHa
Old 03-23-2006, 10:32 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Like ey8 said if there is a small bit of it sticking out then you can probably get it out with a pair of pliers. Otherwise you can try to wedge something into the center of the bleeder and try turing it out that way. Something like an easy out but I dont think they make them that small. SO maybe an old drill bit or something taht will catch on the inside ot the bleeder that you can then turn it out.
It ould be the same as drilling out a bolt in teh center and then turning it out with an easy out.
Hope that makes sense.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 03-23-2006, 11:25 PM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Use a mini screw reverser in the bleed hole. Your turn it in anti clock wise, its a reverse thread so it will start screwing into it, and when it locks, you should be able to just unscrew the leftover bit of screw. Watch you don't get any shavings down into the caliper though.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-24-2006, 11:08 AM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I have had that happen before.
Once I drilled the bleed screw a bit and hamered in an offset robertson screwdriver and that managed to back out the screw.
I know have a couple of reverse countersink bits that do this well.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 03-24-2006, 04:39 PM   #6 (permalink)
View Gary_602Z's Photo Gallery
Sometimes a left handed drill bit will help walk it out but beware of metal chips going into the caliper no matter what you use!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 03-25-2006, 03:59 PM   #7 (permalink)
thanks for the replies guys.. i managed to get it out with a tap & drill screw.
What broke on Hyde ... and an update on the season. JekylandHyde MR2 Forum 12 09-14-2005 01:53 AM
Have ur car Broke down..... Corolla_reps Off Topic 16 01-20-2005 04:55 PM
rav4 brake bleeding rav4jeff RAV4 Forum 1 12-26-2004 08:02 PM
aiming screw _VVTi_ Camry & Solara Lounge 4 03-20-2004 07:57 PM
