turn signal bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2006, 11:25 PM   #1 (permalink)
View lilkevie's Photo Gallery
turn signal bulbs
i was just wondering if it was possible to replace the turn signal bulbs with something like white led bulbs .. and if so what was the bulb size or part for a 00 camry.
lilkevie is offline   Reply With Quote
Old 03-24-2006, 11:31 PM   #2 (permalink)
Supraman
View 94_Toyo_Cam's Photo Gallery
i don't know if you can use led bulbs, but you can use colored bulbs that can be found at any auto store. If you give them the bulb you want to change, or tell them where it is they should give you the part #
94_Toyo_Cam is offline   Reply With Quote
Old 03-24-2006, 11:46 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
You mean for the front?
I accidentally got the clear bulbs for my car instead of amber bulbs and now my front corners and turn signal is white instead of orange. The reflector is still there but it lights up white and blinks white. It's still legal in California so I didn't care.
The stock bulbs are orange. Throw some clear bulbs in there for $4 or $5 per pair and they'll light up white if that's what you're trying to achieve.
The bulbs I got are 3457 or 3456 - I dunno which one it is but it's the one with 4 contacts and two filaments inside the capsule. The stock ones are 3157 or 3057 or somethitng like that. The 345x series has the same base but is slightly brighter per the technical specs (draws more power too, less than 5W difference IIRC).
2007 Camry 2.4L 5M
California Law: turn signal color majorgercko1 Camry & Solara Lounge 19 09-15-2005 05:51 PM
Turn Signal blinking Crash2Camry Camry & Solara Lounge 5 07-27-2005 04:14 PM
LED Turn Signal Bulbs, hyper flashing (bulb out warning).....help? any fixes? aleks77 Camry & Solara Lounge 19 07-23-2004 05:14 AM
Clear turn signal lenses? Elizle Archived Corolla threads 3 07-17-2004 02:12 AM
Help turn signal happyvan Camry & Solara Lounge 1 06-09-2004 03:29 AM
