dragging brakes?
Hi,
I removed my front tires today, just from curiousity (I'm learning to do things on my car). I observed that my brake pads at both sides touch the rotor and so there is a slight drag when I turn the rotor. Is it normal? Should there be a clearance between the rotor and the pads? I haven't found any info in Haynes. The drag is not too bad, I can turn the rotor relatively easily with my hands.
The second interesting thing I found was that the right (passenger side) wheel turned completely around even though the automatic transmission was in P. Is that normal? I started to be afraid that maybe my right front wheel was not connected to the engine correctly, so I started the engine while the car was on the jackstands and put the transmission to D. Both wheels turned, although at different speeds, but I assume it was due to the differential.
I appreciate your help,
