Camry Ignition Lock problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2006, 05:26 PM   #1 (permalink)
View Nayak's Photo Gallery
I am not able to turn the key from ACC to lock position.I checked all fuses, they are OK. Just removed CIG/RADIO fuse out, the lock works fine. When i put the fuse back in, lock doesnt work.Want to know what is wrong if it can not turn the lock when i put the CIG/RADIO fuse back in. Any ideas?
Nayak is offline   Reply With Quote
Old 03-25-2006, 09:01 PM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Gen5
Make shure that your in park or neutral. The camry has a safty that wont allow you to take your key out, or wont let it go into lock.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 03-25-2006, 10:51 PM   #3 (permalink)
thanks ,but I am able to take the key out from ACC position. Problem is am not able to lock. I double checked and i am sure it is not because of shift lever position. Is there any sensor or something which might have gone wrong and is failing to detect the shift lever position?
Old 03-26-2006, 11:06 AM   #4 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
Jiggle the steering wheel as you turn the key.
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 03-26-2006, 12:30 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen5
There is probibly something rong with the tumblers in the ignition. The key shouldnt be able to be taken out in the ACC position
Short Circuit Fuse Problem 2005 Camry XLE Phenocain 5th & 6th Generation (2002-2006 & 2007-2011) 5 09-13-2005 09:42 PM
Problem starting 1990 Camry. DPK99 1st & 2nd Generation (1983–1986 & 1987-1991) 4 09-13-2005 03:27 AM
1994 Camry V6: vibration problem JetBlack 3rd & 4th Generation (1992–1996 & 1997–2001) 7 09-09-2005 01:27 PM
96 Camry Starting problem b_azadeh 3rd & 4th Generation (1992–1996 & 1997–2001) 10 01-08-2005 12:37 AM
97 Camry automatic door lock Problem Xichi445 3rd & 4th Generation (1992–1996 & 1997–2001) 1 11-06-2004 12:10 AM
