Originally Posted by white90dx
Tires and swaybars might help out. What size are the tires you are currently running?
Tires:
- Original 185/70
SR14
- Replaced originals with 185/70
HR14 (Several sets over the years)
- Current: 195/
65HR14 - (H-rated 185/70R14 are no longer available.)
- Considered 195/60HR15. (Have used 60-series tires on another car - very pleased.)
- Considered 205/50HR16: Per Consumer Reports: 50-series (and lower) much more prone to pothole damage - especially not good if spouse is driving alone at night.
- $$$ not spent on 15" or 16" alloy wheels was used for much needed suspension overhaul.
Sway Bars:
- Currently stock.
- Considered a matched pair of upgraded sway bars to preserve balanced response & improve handling.
- Considered Whiteline: However, front sway bar "for off-road only."
- Is the upgraded Whiteline rear sway bar designed to be used with the stock front sway bar for on-road applications? Or will front & rear handling characteristics no longer match?
I found the following information on the Tokico web site.
Anti-roll or Sway bars
A suspension does not have to have anti-roll bars, however they are quite common on many vehicles. The anti-roll bar is designed to help reduce body roll or lean. By using anti-roll bars, vehicle manufacturers are able to reduce spring stiffness. Softer springs improve ride quality and they help adhesion in many situations.
Anti-roll bars can also be used to improve handling balance. However, bars that are too large (too stiff) can reduce adhesion on slick surfaces. This is especially true on snow and ice. They can also be a disadvantage for serious off-road driving.
Tokico Blue: Very pleased with handling improvement and ride comfort.
What is your true final purpose for the car? That will help people give better suggestions.
-Charlie
Goals:
- Daily driver in all four seasons (includes ice, sleet, & snow). Note: 8 wheels w/tires. We use 4 dedicated snows each winter for best possible traction.
- Sleeper: first-class ticket to rapid transit without attracting attention (visually or sonically).
- Best possible handling without negatively affecting ride quality.
- Shortest possible braking distance - accident prevention.
- We really appreciate the fuel economy of this car and do not need blazing acceleration (i.e. 0 to 60 in 5 seconds.)
