radiator life - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2006, 09:21 PM   #1 (permalink)
View smkdwnn's Photo Gallery
2nd Generation radiator life
How long do radiators last? I want to replace my radiator before it fails.
smkdwnn is offline   Reply With Quote
Old 03-25-2006, 11:49 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
depends how you treat em.. if u use tap water might cause it to rust faster than dislitted water..
Old 03-26-2006, 09:18 PM   #3 (permalink)
View marc780's Photo Gallery
Well you may feel that this may not apply to you, but my 88 nissan pickup has 298,000 miles. I've changed the piston rings and done two valve jobs, butit still has the original radiator. I just flushed it with tap water every couple years, nothing special, and always kept right ratio of coolant and water inside it. Still seems good and no problems, no leaking heater core or anything other like that, so why change it?
So i guess the answer is it lasts as long as it lasts.
Old 03-26-2006, 09:22 PM   #4 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
they're right, a radiator doesn't really have an expiration date....
I'm not sure if the Gen 2 s have plastic or metalic.. but with metalics, you can take and wield.
with plactic/alumuium..if the plastic cracks, you replace the whole thing.
So just be sure you do your regular maintence and have distilled water and you replace it when you have to. If anything, you'll need to service the hoses and thermostat regularly
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 04-11-2006, 05:05 PM   #5 (permalink)
Official TN member
View tracyf's Photo Gallery
2nd Generation
The Gen2 (at least ours) has a radiator with a plastic tank. I recently (this weekend) replaced the radiator and if you need one, I saved about $55 over Autozone's price by using Radiator Express (think their number is 1800RADIATOR) - I got a new radiator (with lifetime warranty) shipped to my door for $114 - and if they give you a higher price than somewhere else you find tell 'em and they will beat the other price.
God bless
www.tracystruesoaps.com
tracyf is offline   Reply With Quote
Old 04-11-2006, 06:21 PM   #6 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
My gen 2 has a all metal radiator, it can last almost forever, it really don't
matter if you use tap water as long as you use proper amounts of coolant
as they contain anti corrosion substances. You may also consider putting
a mosquito mesh in front of your radiator, keeps those fat flies from making
dents in it, and of course keeps it clean.
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Old 04-11-2006, 07:10 PM   #7 (permalink)
Official TN member
The bugs don't get to mine because the AC grille is in front of it.
Old 04-11-2006, 10:49 PM   #8 (permalink)
2nd Generation
The oem radiator had a crack on the top which is made of plastic so I could not fix it so it was replaced in 1998 with an all metal radiator. In 2006 (few weeks ago) decided to work on the cooling system; change the hoses, replace a seized fan blade (melted onto the motor) replaced the rusty radiator while I had access to it.
I'm averaging 8 years, I live in New York, tons of salt on the road in the winter!
