trunk lock broken (won't turn) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2006, 11:03 PM   #1 (permalink)
View ckamimura's Photo Gallery
Anyone out there has any experience in replacing a "trunk lock cylinder" which won't turn. Also, what's the process to getting it keyed to the original key. Would a locksmith be able to do this or do I have to take to a toyota dealer. I hate to think what they would charge. Thx!
Chuck
ckamimura is offline   Reply With Quote
Old 03-26-2006, 11:41 PM   #2 (permalink)
View 1shot1kill's Photo Gallery
probally gotta buy the lock thingie mines broke too but i don't wanna replace it cuz i got my sounds so you can steal my suonds without opening my trunk!! and plus if they tried to go though the back seats the box is too big !! hahahahha
1shot1kill is offline   Reply With Quote
Old 03-26-2006, 11:41 PM   #3 (permalink)
maybe go to the dealer.
Old 03-27-2006, 12:54 AM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Mine turns sometimes, but I need to jiggle the key.
Does your lock cylinder not work at all?
I have some lock lube that I've been meaning to spray in there to see if it fixes anything. If I remember to use it tomorow, I post what happens.
2007 Camry 2.4L 5M
Old 03-27-2006, 08:19 AM   #5 (permalink)
98 Camry
View dchriste's Photo Gallery
i have the same problem.. the key actually wont go all the way in.. as if someone tried to pick it and left something in there.. i just left it becasue i never use the key in the trunk anyways...there is a metal rod attaching the key lock to the actual trunk lock/clip... i tried removing that to completely disable the key lock.. bad idea, there is a spring in the key lock that keeps pressure on something in the lock/clip and the trunk will NOT open with the handle inside the car if you remove it.. since my camry is a 98 it doesnt have the safety release for the poor passenger in your trunk so i had to get into the trunk and take it apart...
dchriste is offline   Reply With Quote
Old 03-27-2006, 05:47 PM   #6 (permalink)
Trunk Lock - more problems
Talked to a Locksmith. He told me to remove the lock and to bring it in. He may be able to fix it. If he removed it, it would cost me $25. I removed the clip and rod with no problem. But, it wouldn't come out. Here's the problem: The lock, the way it see it, comes out thru
the rear tail lite lens. How do I remove the lens? I have no idea. There are no screws that I can see. Thought about prying it up but I
didn't want to bust the lens. Any ideas? By the way, I have a '95 Camry. Thx!
Chuck
Old 03-28-2006, 08:51 AM   #7 (permalink)
Moving Forward
View Cyorke's Photo Gallery
are you abel to open the trunk at all. IF so once you get the trunk open pull the carpet that covers the center of the trunk lid. You will see some 10mm nuts screwed onto studs in the trunk lid. Take those nuts off and you will be able to remove the center panel off of the car. The nuts are recessed into the trunk lid becuase it is basically two pieces of metal welded together witha space about 1.5 inches in between the two pieces.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
More light in the trunk DIY - by SnakeyeS and Brungold brungold General Discussion 73 02-04-2012 03:43 PM
Cold Cathode Trunk Light (much brighter!!!) Pics Inside-56k No Way SnakeyeS Camry & Solara Lounge 89 02-06-2006 06:36 PM
DIY sort of Electronic Trunk Pop Anshu General Discussion 3 06-17-2005 10:30 AM
My car got broken into! brink General Discussion 10 03-04-2003 10:17 PM
