I was starting with the cheapest, least messy and easiest thing to do.
What year is this engine??
The firing of the spark plugs (timing) is all handled electronically with a crank position sensor, the advance or delay is handled by the PCM and the signal is sent to the coil pack to fire.
The next thing to do is take out the spark plugs and inspect those.
If they are fine, you ned to check for spark. Got to a dark/dim location, then open the main fuse compartment (next to battery) and pull put the EFI fuse. Then connect the spark plugs to the plug wires, and lay them on the valve cover.
have an assistant crank the engine while you are watching the plugs. you can stay 4ft back to do this. crank for 2 seconds, and you sould see bright sparking at the plugs.
If not, then you have narrowed it down to wires or coil packs.
Use ohm meter to check the wires from sparkplug end to the coil end. around 20kOhm if I remember is ok. Bend and flex the wires when you check to look for bad spots. Any higher resistance, then you will need new wires. the total resistance if wires 1+4 should be about same for wires 2+3.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
