cylinder head cylinder block - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2006, 01:40 PM   #1 (permalink)
Banned
View BlackPearl's Photo Gallery
3rd Generation cylinder head cylinder block
i was going through the repair manual for the 5sfe .. i was wondering if i can get to the gasket between the cylinder head and block without dissassembling the cylinder head?? could i just get right to the gasket just by removing the head...well after removing all the other components...ie throttle body valve....clean gakset surface replace new gasket and install arp head studs install everything in order again with the specified torque labeled in the manual??
BlackPearl is offline   Reply With Quote
Old 03-27-2006, 02:02 PM   #2 (permalink)
Da Wagon MaN
View crazycamrywagon's Photo Gallery
2nd Generation
i dont see why not just take the head off along with everything else to remove it and do what you said to do i have never heard of dissasembing the head to but a gasket on before lol so do what you said you think you should do
1990 Camry DX V6 auto
17in Rota Tarmac II wheels
crazycamrywagon is offline   Reply With Quote
Old 03-27-2006, 04:37 PM   #3 (permalink)
Gameroom cash: $368676
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
dude think about it...its a gasket...
RichieRichJP is offline   Reply With Quote
Old 03-27-2006, 04:51 PM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
whe you say disassemble the head what are you referring to
Youmean removing all of the valves and valve buckets and that type of thing.
You will ahve to remove the valve buckets but you dont have to remove the valves if you dont want to. THe only thing is if you are going to have hte cylinder head off you might as well go ahead and replace hte valve stem seals and have a valve job done in the process. You will ahve to remove the valve buckets because you are going to ahve to turn the head over on the top side to be able to clean off the old head gasket material.
You already stated the obvious about removing the intake and exhaust and all of that.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 03-27-2006, 05:24 PM   #5 (permalink)
View Gary_602Z's Photo Gallery
Even if you were going to remove the valves you would not do that until the head was off anyways.
At least do the valve guide seals while it is apart!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 03-27-2006, 06:07 PM   #6 (permalink)
Banned
how would i go about resealing them
Old 03-27-2006, 06:20 PM   #7 (permalink)
Buy the seals
Using a valve spring compressor compress the spring.
Remove keepers.
Remove springs.
Remove old seals
Reverse procedure to reinstall (use assembly lube on new seals)
Do one valve at a time.
Gary
Old 03-28-2006, 03:04 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
No.
The cam bearing caps and camshafts need to be removed. Theres no way you can get to the head bolts without doing this. The headbolts are underneath the camshafts.
Make sure you keep track of the cam bearing caps. Their labeled (I1, I2, E1, E2, and so on) and only go in one spot.
Also keep track of the lifter buckets + shims and where they go. If you get them mixed up, have fun adjusting the valve lash.
I don't know what manual your reading, but download and read the one below if you haven't already done so.
http://toyotanation.com/forum/t62501.html
Do not torque ARP head studs to whats stated in a repair manual.
The torque requirements for ARP head studs are higher then the factory headbolts. Torque requirements are listed on the back of the box (the box the ARP head studs come in).
Use a bolt stretch gauge if you have one. Otherwise use a torque wrench and the supplied moly-lube.
http://arp-bolts.com/Tech/TechInstall.html
P.S. Why do you have 2 accounts? totalreborn and BlackPearl.
I checked the IPs, so don't try to deny it.
"Skoolin' the unlearned!"
Old 03-28-2006, 06:46 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Now I remember who you are, totalreborn and BlackPearl.
Your the tard that photoshoped Tony The Tigers headllights onto your car, tried to pass it off as your own, then tried to scam forum members.
http://toyotanation.com/forum/t103719.html
http://www.toyotanation.com/forum/sh...d.php?p=965910
You sir, are a tard and have been
22r block w/ 22re head 04camcr Hardcore Tech and Competition 4 01-20-2006 08:32 AM
coolant in cylinder 3&4 390FE Pre-88 Toyota Pickup/Hilux 3 11-12-2005 11:44 AM
5s block with 3S head and accessories EnvyMyDrifts Celica Forum 4 09-18-2005 09:22 PM
Cylinder head interchange khark Camry & Solara Lounge 1 12-04-2004 10:51 PM
