9006>9005?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2003, 09:52 PM   #1 (permalink)
View 1MZ-FExle.s's Photo Gallery
9006>9005??
okay, okay. i read the camry/solara FAQs about the 9006 headlight conversion for...a good...45 minutes and still dont get sh1t. i just need some answers. first are those instructions for a gen3 only or for any cam? and have any of you tners done it yet? it sounds like a really cheap effective mod so im pretty interested. if it helps, i have a gen4.5. can my fuses hold up 60sumpthin watts? thanks
1MZ-FExle.s is offline   Reply With Quote
Old 01-29-2003, 08:04 AM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Ive done it on my projector headlights because it doesnt affect my beam pattern negativly, but I woudnt recommend anyone with a reflector housing to try it. It will have an shattered beam pattern and blind people. :
and all that is required is a dremel to remove the 2 tiny plasic "rails" inside of the connector part of the 9005 bulb, and some dremel'ing around the base tabs is needed for the 9005 to "click" in correctly to the 9006 socket.
ratko.org
Ratko is offline   Reply With Quote
Old 01-29-2003, 09:22 PM   #3 (permalink)
View wontonjohnny's Photo Gallery
is this safe to do??? wont it be blindinly bright?
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 01-29-2003, 09:43 PM   #4 (permalink)
what do you do???
take your high beam bulbs and put them into the headlight housing?? or do you use you HB with HB juice in the low beams??
5 speed 3vzfe - RIP
project F23 CL-T
Old 01-30-2003, 10:23 AM   #5 (permalink)
Did somebody say "Nachos"
CorollaKen's Avatar
View CorollaKen's Photo Gallery
Here is where I got my instructions.....
I have never been flashed for having highs in my lows (been a year now).
I have a Gen3 Camry for reference.
http://pub.radium5.com/~legend/LEGEN...d/bulbmod.html
AND
You need to modify the tabs on the base as well (look here for pictures)...
http://vmac.org/~weston/teg/9005conv/
CorollaKen
2005 Toyota Corolla CE Special Edition
Phantom Grey Pearl
CorollaKen is offline   Reply With Quote
Old 01-30-2003, 10:07 PM   #6 (permalink)
Farmer
View caspah's Photo Gallery
I tried this today in my Gen 4.5 camry. I got a pair of 9005's from walmart and changed one of them around to fit in my low-beam socket.
Like Ratko said earlier it doesn't work very well with reflector housings, in my case the beam was pointing down at the road.
It was quite a bit brighter than the standard lowbeams but it doesn't help if the beam is aiming down. :roll:
caspah is offline   Reply With Quote
Old 01-31-2003, 10:24 AM   #7 (permalink)
[ Crazy - Dog ]
View TOM'S CAMRY's Photo Gallery
The things of you guys talked about is that modify the 9005 and put it into the headlight in stead of using 9006?
As I know the 9005 also is the day light, is that any other different between 2 bulbs?
I have a question, how can I make the day light off when the car is running?
Calvin
Calvin
94" Gen3
4 pieces Clear bumber lens, K&N Drop in Intake, PIAA 4150K Headlights
ISImpression.net
TOM'S CAMRY is offline   Reply With Quote
Old 01-31-2003, 11:26 AM   #8 (permalink)
View rpj1984's Photo Gallery
Calvin
Yes it is to modify the 9005 and put it into the 9006 and the 9005 is the high beam(more wattage, no tip on the end) and the 9006 is the low beam(less wattage, tip at the end)
rpj1984 is offline   Reply With Quote
Old 01-31-2003, 11:48 AM   #9 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
More wattage than stock low beam and more lumins. The wattage rattings for both the High and Low beam harnesses are the same so you won't blow or melt anything. The conversion will work for any car with the 9005-9006 configuration.
I did mine almost 2.5 years ago and I've been running the same two sets of Sylvania SilverStars that way with no problems.
Mine work great in the stock reflector housings. You will need to re aim them tho. ...and no my brights don't shine too high. Its hands down the best DIY mod I've done yet.
I've done the Halogon conversion on my Vette and followed it up with the 9006>9005 conversion too.
btw~ I did the write up on the FAQ page and I believe I was the first to do the conversion on a Camry.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 02-11-2003, 07:45 PM   #10 (permalink)
View oibone781's Photo Gallery
Didd anyone do this on after marker 100w 9005, did it burn wire harness, and after cutting the top tab will it still fit in the 9005 whole?
oibone781 is offline   Reply With Quote
Old 02-11-2003, 10:28 PM   #11 (permalink)
I just did this modification tonight, but the 9005 were just as bright as the lower wattage 9006 bulbs did i do somthin wrong, shouldn't the 9005's be brighter?
Old 02-11-2003, 11:22 PM   #12 (permalink)
was the beam on the floor broken like everybody described?
Old 02-12-2003, 07:16 AM   #13 (permalink)
when i did it, it look exactly as if i had the previous low wattage 9006, there was no difference at all. Did i do anything wrong
Old 02-12-2003, 01:04 PM   #14 (permalink)
View gqdabien's Photo Gallery
How are the silverstars for 9005?? I'm planning on conversioning this by just buying the 9005 sockets and connecting it to where the 9006 are bc mine are melted. Btw this is gen3 camry, will i get great lighting by going two sets of 9005 sylvania silverstars in headlights?
ps. also will my plan work? by buying 9005 sockest and wiring them up to where the 9006 sockets for low beams are now?
gqdabien is offline   Reply With Quote
Old 02-12-2003, 02:52 PM   #15 (permalink)
I Was thinking about doing that also, should get awesome lighting, is this conversion possible, and where do u get the parts?
