Brake bleeder valve size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2006, 01:33 PM   #1 (permalink)
View NathanOfSeattle's Photo Gallery
For my 1997 Lexus ES300, does anyone know the size of the "nipple" for each of the bleeder valves on each caliber? I need help determining what size clear tubing to get to assist me with a brake fluid change job I need to do on my ES300. Thanks!
NathanOfSeattle is offline   Reply With Quote
Old 03-28-2006, 05:29 PM   #2 (permalink)
Gameroom cash: $304355
I would guess that 1/4 ID tubing would be about right. That's what I use on my Camrys.
Mike
Old 03-28-2006, 05:48 PM   #3 (permalink)
Official TN member
View tracyf's Photo Gallery
Or just spend $7 and get a one-man brake bleeder kit at AutoZone, with reservoir, tubing, and magnetic lid that holds it above the wheel you are bleeding.
God Bless
www.tracystruesoaps.com
tracyf is offline   Reply With Quote
Old 03-28-2006, 07:46 PM   #4 (permalink)
Thanks, I like the idea of the materials included in the one-man bleeder kit. This will be my first time doing this. Would pumping the brake pedal be sufficient to create the pressure needed? If so, could someone explain how many pumps I need, things to avoid, as I move from caliper to caliper.
Also, for those experienced, are the pressurized bleeder kits worth the extra money?
Old 03-29-2006, 01:59 AM   #5 (permalink)
Official TN member
I gave someone else instructions on the one-man brake bleeder kit here:
http://www.toyotanation.com/forum/t127494.html
Please ask if you have any other questions. I have benefited from other people's knowledge on here and owe the same.
God Bless
Old 03-29-2006, 08:05 AM   #6 (permalink)
View hooRAH's Photo Gallery
I tried to use aquarium tubing because it was lying around the house. It was just barely, and I mean barely too small. So, if you happen to know what size that is, the next one up.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 03-29-2006, 07:27 PM   #7 (permalink)
God Bless
What a greate write up. Thank you! I sent you a PM with some more questions. Thanks for your help!
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 25 05-04-2012 11:57 AM
Rear Brake Valve Replacement spageroni 89-95 Toyota Pickup/Hilux 5 03-02-2006 01:31 PM
Brake line size?, or what to get? toysarefun Camry & Solara Lounge 2 11-21-2004 08:27 PM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
Good discussion on x-drilled/slotted brakes EKam Hardcore Tech and Competition 44 12-29-2003 11:46 AM
