Can my camry use a bigger oil filter? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2003, 01:19 AM   #1 (permalink)
View Ken4's Photo Gallery
My 2.2L 5sfe camry uses a 90915-10001 or 90915-YZZC5 toyota filter. Is there any harm if I use a longer filter like the 90915-10004 or 90915-YZZA6 designed for the newer 2.4L 2azfe camrys?
Ken4 is offline   Reply With Quote
Old 01-29-2003, 10:09 AM   #2 (permalink)
View STR8PYP's Photo Gallery
Why would a longer filter matter? Just stick to the factory recommended size and you won't have any issues.
Steve
http://www.schung07.com/
http://www.thewheelsupply.com/
STR8PYP is offline   Reply With Quote
Old 01-30-2003, 12:57 AM   #3 (permalink)
View henry bui's Photo Gallery
you can use 4runner oil filters. from their 3vzfe engine. i think thats what it is. the engine in the 99 4runner. i accidentally put thatn on my car instead of my moms and when i noticed there was no problem
doubt that would be a problem either. should work fine.
henry bui is offline   Reply With Quote
Old 01-30-2003, 06:58 AM   #4 (permalink)
I was curious, so I cut open both filters to see what's inside.
Here's the one for the 2.2L 5sfe:
Yikes! No bypass valve!
Here's the higher quality one for the 2.4L 2azfe, the red rubber is softer and more pliable:
Old 01-30-2003, 04:24 PM   #5 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
if the gasket and the threads are identical, then go nuts, i like the looks of that longer one too, think i might look into this for the next oil change, ,but for the 3vz
-Nick
Nick is offline   Reply With Quote
