gasoline smell in engine bay - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2006, 12:19 AM   #1 (permalink)
Sleeper-still sleeping
Redline's Avatar
View Redline's Photo Gallery
3rd Generation gasoline smell in engine bay
Did a search...found a few relevent points to my problem, but I need to confirm these since the post I found is almost a year old:
- faulty/worn O2 sensor downstream of cat will cause engine to run rich
- faulty sensor will cause poor gas mileage
Now, the symptoms that I'm getting:
- slight gasoline smell in the engine bay (getting into the cabin)
- kinda noticed a higher fuel consumption; gas needle is lower than usual as this point in the week (I usually fill the tank on Thursdays)
What I've done to the car recently:
- new exhaust piping from the cat back, using stock resonator and aftermarket muffler (just done this past weekend)
- engine treatment additive (to engine oil) about 2 weeks ago prior to emissions test.
Now, here's my question: what possible factors could cause the gasoline smell in the engine bay? Faulty sensors (in engine bay and/or downstream)? Fuel pump? Something with the new exhaust piping? Other?
I need some help...THX!
Redline
2003 4WD XR Matrix
Mods: HID low-beams, Injen CAI, Pioneer mp3 H/U, Tein SS Coilovers, Hella foglights, Corolla TRD STB, TRD 17" alloys w/ General Exclaim UHP, stubby antenna, KVR cross-drilled rotors, 35% tint all-around.
Pending: DIY-fix for front lip kit...
Redline is offline   Reply With Quote
Old 03-29-2006, 04:01 AM   #2 (permalink)
View karazy's Photo Gallery
You should get a CEL if the sensor is gone. It's possible that you have a fuel leak. Sometimes it can be very hard to determine where the fuel smell is originating from.
karazy is offline   Reply With Quote
Old 03-29-2006, 06:21 AM   #3 (permalink)
View celica supra 83's Photo Gallery
a bad catalytic converter can cause a gasoline smell too,this probleme sometimes occure with the newer corolla and camry.
celica supra 83 is offline   Reply With Quote
Old 03-29-2006, 10:26 AM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Leaking fuel injectors (worn pintle drips fuel into cylinder when engine off). Fuel injector O rings wear out and seep. Leaking fuel filter or fuel lines.
Misfires spray fuel into cylinder but you don't get complete or any combustion of fuel so you smell it.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 03-29-2006, 01:05 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Like csaxon said, injectors. Look closely around the fuel injectors. If there is a suspiciously clean area near one (or more) that almost always indicates a gas leak (Gas being a good solvent, it cleans the affected injector nicely).
I've also heard that the charcoal canister can sometimes emit a gas odor. Don't know how to isolate it though...
Kep
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
How to remove the 3sfe from the engine bay... vuedoo Camry & Solara Lounge 40 12-17-2005 07:49 PM
What your gasoline is really doing to your engine Ratko General Discussion 25 04-05-2005 10:06 PM
