Air Intake Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2006, 11:13 PM   #1 (permalink)
View YYY Camry's Photo Gallery
3rd Generation Air Intake Filter
Like last year I bought an Air intake system, I was wondering how often the filter needs to be cleaned and how to clean them. A friend told me to clean it every 15,000 miles with water and soap if I didn't have a cleaning kit, should I use dishwasher soap?
Also I've seen those 50mm AIR BREATHER FILTER, what is that for? What good would it be if I put one of those in my Camry?
THANKS
YYY Camry
YYY Camry is offline   Reply With Quote
Old 03-29-2006, 11:31 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
should just clean it once a year... more often if you drive in dusty or sandy conditions.
You might just be able to get away with using soap and water... but if you get the cleaning kit, it is reusable anyways.
most important-- reoil according to their directions.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 03-30-2006, 12:13 AM   #3 (permalink)
Noob :-)
View ST185's Photo Gallery
You only wash it if it is washable.
K&N is made from cotton and washable but you must reoil it after washing.
Some cheap paper filter is not washable and doesn't use oil to trap dirt like K&N.
In this case, use the air to blow it from the inside.
Most breather filter are for PCV or fuel system.
It prevent dirt entering crankcase ventilation system.
You don't really "need" it.
93 ST185
ST185 is offline   Reply With Quote
Old 03-30-2006, 12:40 AM   #4 (permalink)
View Tarzan's Photo Gallery
Yeah,
You can't wash regular air filters at all, just blow off the dirt. Now K&N you can wash with water and reuse, just reoil it. That what I got.
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 03-30-2006, 04:36 AM   #5 (permalink)
100 fwhp stock gen 3
skyliner650's Avatar
View skyliner650's Photo Gallery
just cut a hole in you hood and stick the air filter on th top so u can get true ram air
and o yea the rain will help u wash it hahahahhhaa
jk jk
yea k&n would be the best choice because they last a really long time and u get to wash them
but the ebay ones are fairly cheap and u can just replace them every year or so.....
STRAIGHT PIPE REMUS EXHAUST(CUSTOM)
ENKEI 18'S
TENZO SPRINGS
EVERYTHING ELSE IS STOCK
skyliner650 is offline   Reply With Quote
Old 03-30-2006, 10:53 AM   #6 (permalink)
Thanks guys for the info. I have one of these that I bought from ebay, http://cgi.ebay.com/ebaymotors/CAMRY...spagenameZWDVW
What do you guys mean by re oiling it? what oil? Should I was wish dishwasher?
YYY Camry
Old 03-30-2006, 03:43 PM   #7 (permalink)
You just wash it by flusing water thru it. There is a special oil that K&N makes that you use to reoil it. Because when you wash it, you wash away the oil too.
94 Camry Coupe
Old 03-30-2006, 04:07 PM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
d9ont wash K&N filters ifyou want to honor the unlimited mile warranty on them.
washing destorys te fine gotton threads that is used for filtering large dirt particles out.
they also work best when dirty as the larger dirt particles (trapped on cotton) will stop slightly smaller particles from passing. the oil suspense microbits of dust from the cotton trapped them.
just give it a knock to clear out any big bits and a quick spray of oil from the inside.
terrastrife is offline   Reply With Quote
Old 03-31-2006, 11:41 AM   #9 (permalink)
As per the instructions from the K&N oil kit. It says to flush with water, let dry and reoil.
94 Camry Coupe
Old 03-31-2006, 04:22 PM   #10 (permalink)
I don't have a K&N filter, I have a Aspec Short Ram Air Intake System
http://www.eautoworks.com/html/ape-a...eaning~Kit.htm from this site which is the best cleaning kit, or is there a better one?
YYY Camry
custom intake and cold air box(kinda) for under $20 2000AVALON 2nd Generation (2000-2004) 4 06-02-2007 11:56 PM
Short Ram Air Filter The Wolf Camry & Solara Lounge 2 07-25-2004 03:18 AM
The Best Air Intake System (Cold Air, Ram, or Custom) aleks77 Camry & Solara Lounge 6 07-21-2004 11:50 PM
replacing air filter busted_ride Camry & Solara Lounge 1 02-10-2004 01:27 AM
filter question! boroEF Hardcore Tech and Competition 14 04-21-2002 07:07 PM
