Originally Posted by WhiteRabbit
I figured the thermostat being stuck would cause longer warm up times, just don't quite understand how it goes from normal to cool, and vice versa.
The thermostat is not opening properly. IE: stuck thermostat.
When the car is moving theres more water flow as the water pump is spinning faster. Thats why your noticing the temp drop when your moving and it go up when you slow down.
I've had the same problem, except the thermostat was stuck closed.
My coolant is pretty shitty colored too, can that affect the thermostat?
Rusty color?
You can try using a flush additive the next time you do a cooling system flush.
Not sure if I need to do another radiator flush (did it a couple of months ago), or if a slight oil leak on the back of the block is leaking into the coolant somehow...
If oil is leaking and mixing with coolant, the coolant will be milky.
As for the oil leak on the back of the block, check around the valve cover. It could also be a leak from the power steering pump since its near the back of the block.
