I have a 1993 XLE V6 Camry with an auto tranny. When the transmission is cold (and only when its cold) the car will feel sliggish and then the transmission will feel like it shifted from 1st to 3rd (the rpm's will suddenly drop). The car doesn't stall but it has to downshift to regain its power. Now here is where it gets weird, it only does it once a drive on its first shift out of first (usually when it sits overnight or after work, and gets cold) , after that the car runs and shifts fine. When the engine/tranny is warm, it is fine.
Now do you think that it is a sensor? The fluid is full and clean, there is no signs of burning (smell test) and the color of the fluid is red.
Has anyone else had this problem?
1997 Toyota 4Runner V6 SR5 4X4
-TRD Supercharger-TRD Tranny Cooler
-265/75/16 Michelin LTX AT-PP 1 inch lift springs
-Deckplate mod w/amsoil
1993 Camry V6 XLE *SOLD*
-Intake
1992 Toyota Celica All Trac (ST185) 64,000 original miles
- Intake
- Upgraded CT 26 w/46 trim
- 16in wheels
- Stage II clutch
- Boosting @ 11.5 psi My 4Runner and Celica site
Mine does something similar to that. In the morning when i first start driving the first set of shifts through the gears usually takes longer. Such as it waits until 3000RPM to shift from second to third under normal acceleration. could this be normal to warm it up?
Ideas??
How long have you had that tranny cooler installed? The reason I ask is since I installed mine, my transmission seems to shift slow and late when its cold. It takes a good amount of time for it (transmission) to warm up. Maybe its just because it has remained below freezing since I installed it.
I believe the tranny cooler is on the 4Runner and the problem is with the Camry. Mine does the same thing, sort of. Only when it's cold, and usually the first time shifting from 1st to 2nd I believe. It hesitates around 2k rpm, and will then continue after a few seconds of hovering there. Never really got it figured out, but it hasn't been much of a problem lately.
If torque actually won races, wouldn't we all be driving diesels?
I think when your car is cold the tranny will shift very slowly just to prevent potential damages. It'll also stick to 2nd or 3rd gear when cruising instead of 4th. After 10 mins of drive or so it'll drop down to 4th.
I would say try to warm up your car for a while (5-10mins) and just accelerate slowly and try to keep the rev low until the temp guage goes up to a decent temperature.
Other than that I don't know how to solve the problem, but the V6 tranny is known to be near-bullet-proof so there shouldn't be anything to worry about. If you're trying to track it then that's a different story. :
doh....I laugh....but only 'till I track come spring.... :oops:
HaHa
"Life is a deep sleep, of which love is the dream..." Ripped...and the girls are loving it.
Thanks for the suggestions guys.
My parents bought the car new, and sold it to me last year. It started doing this last summer.
Here is what I have done:
- 110,000 Miles: Took off the pan and changed the filter (No metal chunks and filter still looked good) Replaced 4 quarts of fluid.
-116,000 Miles: Removed drain plug for transmission and replaced 4 quarts, fluid was still good. Added a transmission conditioner that didn't do anything.
-120,000 Miles: Removed drain plug for transmission and replaced 4 quarts, fluid was still good. Added a NAPA transmission conditioner
After I added the NAPA conditioner, it shifted very smooth, for about 3 months. Now it is back to normal.
I am not sure if it is the transmission, it almost feels like the engine is running rough... I have heard on older 4Runners that the T.P. (throttle position sensor) can go out of adjustment. Has anyone had this problem with the Camry's??
Thanks again guys!!
-Intake
- Intake
- 16in wheels
- Stage II clutch
I have a question about something similiar. All the time now right after the car shifts the rpms will drop fairly quick and then go back up just a little. I don't remember my car doing that before. Any ideas
1992 Toyota Camry 4dr
5SFE->??? Just wait and see!
-Intake
- Intake
- 16in wheels
- Stage II clutch
